Barry. looks nice Hope you don’t bin it if you run into another problem I’m with the others like to see it finished. You did a great job on the cockpit too
Not likely to have another real issue now except for decals and, if so, I will just work around it as I have previously. It really only was that fuselage fit issue which, if not corrected, would have been fatal. Brute force did the trick.Barry. looks nice Hope you don’t bin it if you run into another problem I’m with the others like to see it finished. You did a great job on the cockpit too
HI Barry fantastic work an where is the spotlight fitted on the tail as im readind on the orange bit behind the tail ?I have finished the fins
here is the outside...
the innerside.
as you can see I have some touch up to do with paint and then a varnish coat or two and they will look all hunky dory....
Await final fitting. Painted clear red and ready.HI Barry fantastic work an where is the spotlight fitted on the tail as im readind on the orange bit behind the tail ?
chris
