SimonT - 1/35 Tamiya Sdkfz.223
Jim - thank you very much. It doesn't matter if yours doesn't have all the details if you enjoyed building it. You can always have another go - try the Hobbyboss one. More detail OOB than the Tamiya yet not stupidly expensive
I donned my pith helmet and safari suit and went on an expedition into one of the deep dark stashes hunting the Hobbyboss 223. Duly captured and dragged kicking and screaming back into the light. They obviously have no idea on the ammo tins either as the etch racks are left empty :rolling:
The long thing at the front of the HB gun mount is the jacking mechanism toothed rack - there is no ammo tin
For what will be seen an approximation of the workings and ammo tin will do nicely
not done a right lot more
the right bracket of the air filter was annoying me, I tried to fix it and mangled it instead - replacement made and installed
added the arms that fasten the mg mount to the turret ring so that the mg follows the turret - made from armature wire
flattened the ends in pliers and fastened to the turret ring with the inner end then CA'd to the mg mount
post script......
turns out I had the info all along on the Toadman cd :rolling: :smiling5:
Guess they found some since the book was written
Even better :)
But … are those watermarks on every picture in the CDs he sells sold?
No the watermarks are not on the cd - I have cropped these pics, reduced the resolution and watermarked them to make it obvious where they originated. The cd's (or downloads as they seem to be now - although site hasn't been updated since 2018) generally contain two or three hundred high quality photos and are definitely worth the asking price
223-059_2020-7-29.jpgd
tonight I looked at the etch fire extinguisher holder
the Eduard instructions would have you try to clean off moulded straps without destroying the extinguisher - looking at references the kit version is not that good anyway so it was easier to just make another one from rod, punched disks and a bit of brass wire
installed on the rear wing it I think it looks ok and definitely better than the kit version
Ah, OK :) You had me wondering, because watermarks that extensive would make the photos almost useless, so I couldn’t imagine really he sold them like that.
Hi Simon
I like the little fire extinquisher. 'Looking in' you'll not see a great deal of your efforts.
Not very amazing really John :smiling2:
Jim - extinguisher is passable and should look ok under paint and a load of dust. With the crew on top that I hope to add you won’t see much at all inside which is why I didn’t spend tons of time detailing - just the bare minimum to suggest the various bits of kit in there :thumb2:
You may well say that Simon, but to us mere mortal the detailing and scratchy is just that.
exhausts assembled and the gaping holes filled - still need to drill the ends out and fit the outer skins to the silencer boxes
made a cover for the spare wheel from Duro
I then assembled the aerial
these are the kit mounting points on the aerial - rectangular blocks
so I filed them down
once glued to the mounting poles I finished filing them down to match the diameter of the poles
the poles had the solid ends scraped out and pivot pin ends added
the top ends should pivot as well so that it can be lowered so pin ends added
and how it looks overall with the aerial installed
Simon,, GREAT job of detailing..what is Durk? That the spare cover is made of? I’ve never used that material..keep up the fantastic work
Cheers Joe - Durk?? I think your spell checker got at that one :smiling2:
Duro is a sculpting putty (not filler) also called Kneadatite or Kneadatite Green Stuff
It is a two part putty (one yellow strip and one blue strip - when mixed turns green) with a plastic like consistency - takes detail well and never sets rock solid so if thin bits get caught they tend to bend slightly rather than snap off
It can be rolled out wafer thin and cut to shape with a sharp blade for straps etc
With it being plastic like you can even superglue it to something before it cures to anchor it down and then sculpt it in place
It is not water soluble and does not sand very well
Some people mix it with Magic Sculpt to change the consistency
Cheers Steve - getting there.....
added handles and filler caps to the previously assembled cans - the handles will get tidied once the glue sets
I have found it is easier to do them once glued in place - when loose they are rather fragile
front tow hooks added
rear tow hooks also added
jack added to rear right mudguard
not the best jack so it got a little bit of fettling including chiselling out the foot plate
kit solid mounts carefully removed and replaced with the etch mounts
I noticed that in a lot of the reference photos the lights had covers over them so I sculpted some covers
the mounting points on the hull are not very good and will need some filling - should be fun as not easy to get at
Hi Simon
Headlight covers look good. Jack is improved.
Just beautiful. PaulE
Simon. As always outstanding work I’m liking the updates your doing. We all can learn by your examples
