Nice progress. Are you familiar w/formula for weighting rolling stock (HO is initial weight plus 1/2 ounce per inch of length)? Almost all garages now use stick on wheel weights to balance wheel/tire assemblies. They'll have a bucketful of takeoffs they can't reuse. You can cut these up to fit wherever you have space on the car or in the load on/in it to achieve the proper weight. Once done to your fleet you'll be amazed at the difference. Just remember the center of gravity counts, so keep the weight as low to the rails as possible. BTW there is a model of that loading ramp available in HO. Check your local importer. HTH. PaulE
Hi Paul, I wasn't a wear of that putting weights down onto the axles , where can you get the weights from , can't find much info on the next, can now understand why wagons wobble , see that on video clips. I bought those cheap from China passenger cars to do with that Hornby layout you buy a part each week, I be keen to put the weights on those wheels .
But will try the weights on the bogies first, have Con-Cor passenger cars that derail , cost me a lot of money $500 for 9 Union Pacific cars ., I love this forum .
Many thanks Paul for you advice, looks like I have some work ahead.
Take care Tony
