Time to share my control panel and DC wire madness
First pic the block wire strips where control panel connects to the layout , pic two in underneath the same module the DC wire madness, which I plan to improve, pic three my pride and joy my control panel. Chris I used a drill vice to drill the holes, the only way I could get to be straight , took a week to drill,
The Led lights indicate each throttle, three throttles on a 4 way rotary switch, forth light is spare, a friend offered to do the wiring thanks to him it works, I made the panel, 20 blocks all up, will get all used up, I have two remote throttles form the main line so I can follow the train around.
Lucky last is the speaker plugs I use between each module to plug up very easy plug and play, now the fun begins working on the modules tomorrow .
Tony from down under
