Barrel Hinge or Concealed Hinge.
Looking for the ones used in dolls houses or jewellery box manufacture , will post link when found
smallest i can find so far @ https://www.ebay.co.uk/itm/Hardware...dden-Concealed-Invisible-Hinges/323375983041?
Do they have to be the round type? RC guys use flat hinges they glue into slots.
They also use these at 2.5mm which is the smallest I can find.
Could you use the side hinges from an old pair of spectacles Dave?
When you look through the pictures you see some at a different angle, don't know where the 10mm comes from but it certainly doesn't look 10mm.....From the given sizes these are 2.5mm wide (I assume this is basically the the length of the pivot) and the width of the hinge piece is 10mm. I'm not concerned about the length as I could always cut them to fit, but my maximum width is only 6mm. I will have a mooch around and see if I can find any smaller ones though. Thanks Karl.
I seen that, but the picture shows both angles and it's clearly not 10mm if the hafts are 2.5mm, and it would defeat the point of these hinges.If you look at the ebay sales page Karl, you'll see where they ask you for the size you want. The dimensions are in there.
