The bridge is nearly there, but a lot of work still ahead, it sure needs the second side beam what would be nice is 12 feet in one full length, not so , I will check out the timber mob on Tuesday if they have lengths of 19 mm pine 12 feet in lengths and 2 and a half inches high
Pic one the joining of the two 7 foot lengths, I used a length of 42mm square timber to level the two half's took some time, finely under way screwing the side beam on, finely finished screwing the side beam in place, sadly wasn't in one full length, and yeah that is where the bridge started to sag, I clamped on two 6 foot lengths of ply that helped, will for sure nee the second beam.
The next two pics, second pic not so bad, third pic you can see a staging there, the bridge is now in the garage, fits nicely, wont be back to the bridge till Wednesday when I ill cut the the end sections, be five feet in length hopping that will stop the sagging, a lot of work building bridges.
Getting there , Tony from down under
