1/35 Great Wall Hobby 12. 8 cm Pak 44 .
No problem. I think you said elsewhere youd watched his channel. He's actually just about to publish a book, which I've had on order for a while.
Quite like the guy Andrew, he's tried really hard to make a go of his channel. I remember when he filmed in his front room , then a small shed before moving onto a building.
Sometimes even some quality time at the bench can wear you out!
Ah yes indeed, time flew by Si. Looking fwd to getting those bricks done though, then the real fun begins with the detail.
Hi John
This has been progressing well and quickly. Love that idea for cobble stone making. The building is very well thought out - all those years working have helped I'm sure.
Hi John
Hi Jim, thanks for looking in. Yes think it has helped a lot.
Back after a massive brick scribing , added a couple of buttresses to one wall and a header of 4 bricks to the wall tops.
Some of the buildings where there is going to be no damage have had backing white card glued to the rear. This will be painted black and then the window frames added.
No comes the part of painting all the individual bricks, but first a coat of light grey made from some cheap acrylic paints using Daler Rowney System 3 . Well not really cheap but compared to 17 ml of Vallejo they are.
First just the foam board scribed, marked out at 3mm then using a fine .5 pencil the brick line ids down , then the vertical bricks lines.
Hard to get the courses to all match up, but when painted they all blend in.
The start of the first coat of light grey, this will when dry given another coat and a light surface sanding, this will leave the mortar bed.
Following this a black wash will be done in the same manor.
Now sitting in the kitchen drying out.
Thanks for looking in . comments welcome.
John.
Hi John that's jaw dropping stuff:thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::thumb2:.
Brilliant.
John,
Firstly sorry for missing so many updates. Just had a catch up the gun itself looks great. The groundwork is superb mate this will be spectacular .
Watching avidly and taking plenty of notes for the future.
Brickwork is looking spot on John.
John,
No problem Paul with the amount of builds going on it's hard to keep up.
Thanks Andy.Keep the pad ready as more to come.
That's EPIC John
Wow!
Very kind of you to say Neil, thank you.
Evening John,
I thought you’d been quite of late.....I can see why now :surprised:!!
Blown away mate, excellent brick work:thumb2:
Those building be fronts are in looking amazing. Really top notch work!
ATB
Hi John
Building coming on a treat.
Thanks Jim .
Evening John,
Cheers Si. Glad you like it .
ATB
Kind of you too say Andrew, more to come.
John. Looks like the work of Architect Nice
Thank you Lee, takes time but hope it will be worth the effort .
John,
HI John what Scottie said cant say any more than that its brillant work m8 an lookin forward to more will there be flames ? lol as i had some on me head lol :face-with-head-bandage: :rolling:
chris
chris
Hi Chris, yes there will be fire damage ! ( only a little unfortunately as only a small roof area to set light to.:nerd:
Morning all, nice sunny day here in Lincs. Managed to get a second coat of the grey on the building walls this morning, now drying.
John.
