1/35 Great Wall Hobby 12. 8 cm Pak 44 .
Thanks Chris and Andrew.
This morning I sanded the building sections very lightly with a foam sanding pad. You only need to remove the top layer of grey ;leaving the black and grey in the joints. Looking through my acrylic paints I didn't have the correct browns so ordered online. This can now wait while I concentrate on Simons Build.
Varying the pressure will help when the painting starts.
Thanks for following.
John.
WELL John been havin another look at your wall an i think its very realistic an when will we see flames ? lol
chris
chris
Oh not for some time Chris, have to paint all those bricks first ! then apply some pigment, build the roof then it will suffer , on yes indeed :nerd::smiling3::smiling3:
Get the fire engine standin by guys an contact matron John goin for it lol
chris ps SOON
You are rather good at buildings John, better than my local council lol
Lovely work 4BO
StuG u like
Evening all .
Today I made a wash up of black acrylic with 80 % deionised water and a dash of washing up liquid to help the flow. Once mixed I used a 50 mm brush and applied a generous wash to the stone sets and the wall.
Afterwards ( should have done it before ) I applied a thin layer of filler mixed with some PVA on the base again with a smear of PVA. This is just to help with adhesion.
Once done I thought I would try something I had seen on the net, the use of crumpled up cooking foil to use as an imprint. The first try was an effect was a water that was far to rough. Smoothing out the foil was better. Just need to paint and then varnish.
Other fillers and glues are available .
Glue bead on.
"Buttered "
Just as small amount of glue before the water was applied.
Result, quite impressed myself. I'd seen this used on a seascape. One the filler was dry and coloured Silicone was layered on followed by gesso type to give the effect of waves. Of course I won't be having the waves, and varnish instead of the Silicone.
Thanks for looking in. Now to reply to Bob as the posts crossed.
John.
