How To Tell When You Have Lost the Plot ...
After spending two hours making your own cockpit masks, under the decal sheet in the kit box, you discover a set of masks for the kit that you bought previously. Sheesh .... :loudly-crying:
See what I would do in that situation is use it as a divine sign that another kit needs to be bought. If you don't the modelling gods let the carpet monster loose...........
It's like when you accidently buy the wrong AM stuff...........
Hi Karl. The idea to buy another of the same kit has a lot of appeal. I quite like repeating the same kit to see if I can do a better job the second time around. The kit I'm working on is a 1/48 Tamiya Spitfire Vb which is the third one I've done recently, so I should be getting it right by now. I have a soft spot for this particular kit - inexpensive, nice cockpit detail with an instrument panel that handpaints very well, canopy options, and it builds into a very presentable model.
