BattleshipBob
Feel your pain too Carl! You can sort it!Hey, don’t worry, I’ve gone off topic so
Many times I can just about remember myself. This ones turning into a bit of an education .
Sadly for me I used some varnish which obviisly went on too runny which then run under the tape and left sticky shiny streaks at every spar it passed over, consequently I had to run it all off which trying to rub around tiny soars was not easy.
i e now sprayed a few coats of black to get the coverage back in and use as a base for the main hull colours and as the pin stripe itself. However, despite not being able to feel by hand the previous mess I can stll
See within the black paint marking from the disaster. Hopefully this will not show when the main hull colours are done.
Giving me nightmares. Right two coats on the hull, not the right colour but just want to get this croc finished. Its then either being binned or hidden deep in the garage
You can see the raised line but past caring lol
I need to have a good long think about starting the KGV, so annoyed about this build, also thought i had sorted out the hull seams but no they are there for all to see. Been very dissapointing for me. After working on trucks worth £100000 with complex systems and cannot build a plastic ship right, aarrgghh
Off to look a StuG lol
