Getting the 'ground supports' in - only corrugated cardboard, but should hold the 'ground' (no matter what I put on it) though looking at it, might have to use a different base material, as it's starting to bend across the corrugations! Never had that problem with this stuff! :angry: Hope that I can sort it - otherwise it'll mean having to try and cut straight lines with wood - and I've never had much luck with that!!!!
Have a load of this cardboard, got it when I was delivering some Chinese mopeds to a shop and thought that "it would be useful" - it has been used for loads of things, from target backboards to sending a heavy tool through the post!
