Joe's 1/22 Artesania Latina San Francisco Cable Car
Nice work Joe. Such an iconic vehicle!
Tried to look one up on line to buy. Appears that Artesania have discontinued this kit.
There is another company OCCRE who make a SF cable car kit in 1/24th scale.
The closed passenger area is in the middle on their kit.
The inner formers for the roof ends were shaped to create a slope for the strips that will later make up the roof ends. The strips either side of the roof edge were blended.
The roof ends are made up of strips of wood that are attached to the structure and once dry at the ends and middle former, will be bent down to the roof ends. Then they will be sanded smooth to the shape of the roof, and filled with putty as required to create a smooth surface. Much like the cable car cabin walls were earlier. The same bunch of strips are used to build the clerestory roof cover later on.
Many strips later
It looks like a dog's breakfast at the moment. Once dry I'll bend the ends down, clamp them while they dry, and once that's complete, sand the new structure to shape.
Joe, I am buidling the same kit and have arrived at the Roof build section. Did you water-mist the 27 (or so) slats at either end in order to soften them for bending to conform to the desired shape? What was your complete process? OR was it just a matter of glue, clips, tape & rubber bands??? Thanks - your blog has given me the confidence to complete this challenging kit!!
Nevermind Joe; I reread your post and it makes sense now.
Hi Joe, as others have said, your work is top notch! Coincidentally I have been working on the same kit for about a year, off and on.
I just joined this blog as I was desperate to get some guidance/answers to my own SF Cable Car build. For reference, I've just today finished the 2 "trucks" (a.k.a. Chassis) and about to begin the roof portion of the project. Like you, I hesitated to install & cement the Grip Ass'y since, w/out a display base, the protruding portion of the grip will create a stability issue when I add the trucks to the body. I will use your example to guide me in fabricating my version of your display base. Thanks very much!
Hi Christopher, I look forward to seeing your rendition of this kit. Thank yo
Hi Noel. There are two types of San Francisco cable car, the Powell Street version, and the California Street version. The Powell Street cable cars can only be operated from the front end, and require turn tables at the ends of their routes. The California version can be operated from either end, and has the enclosed passenger area between the two ends as you said. This means the California version doe snot require turn tables, the operator simply gets out and goes to the other end. Be good to see a California version built.
Hi again Christopher. Sorry, I haven't been getting on the forum as much as I'd like to lately. I see you have resolved the situation and possibly progressed. I'll take a look to see if you have a build log. Happy to help where I can, hoping my build thread is of help to you. Cheers.
Joe, thanks for your explanation about the two cable car lines, and why there are single ended and double ended cable cars.
Have been toying with getting the Occre one as it appears to be quite easily available.
Occre have some interesting videos of their one being built on their own website, plus build videos of many of their other kits too.
Not heard of Occre, but a quick search online shows it might build up into a really nice rendition of the San Francisco cable cars
Well it's been about 4 years Joe and I'm just now about to finish my version of the Cable Car. There were long periods where it just sat on the workbench, awaiting my return (facilitated by renewed courage). The Roof and upper Cupola were by far the toughest part of this build but I am proud of the result. The fore and aft of the cupola roof overhangs turned out shorter than yours - don't know how I messed that up (conversion from metric). QUESTION: to attach the yellow/red marker lights, the bases are not flat. Did you drill small holes or indentations in the roof corners to accommodate the protrusions in the marker light bases? Before I apply the decals I will assemble the expanding barrier gate using your tiny screw method. Did you ever create a suitable base and display box? Chris
Good to hear your cable car is approaching completion Chris. To answer your questions:
The lights: I think I sanded the base of the light to match the roof angle and fixed them with CA glue. You could drill a hole.
Good luck with the tiny screws, you'll be tired of the sight of them by the time you complete the gate. :dizzy:
I did create a base. You can see it in this thread. The completed build thread is here: https://www.scale-models.co.uk/threads/1-22-artesania-latina-san-francisco-cable-car.36829/
I look forward to seeing your cable car, best of luck
Responding to this thread a number of years on.
I have just completed this particular kit having tracked one down in the UK about two years back.
Did one hell of a load of modifications to it (like fitting actual sliding doors for example) and also a number of my own scratch built additions.
Well it did take me a long way away from my usual car models, but I did enjoy building it and fitted it onto a base with clear acrylic cover.
A bit of an oddball scale in 1/22nd instead of the more usual 1/24th, but builds into a quite large impressive model with a bit of character about it.
Good to hear another one has been completed. Sounds like you really went to town on improving the details. Do you have photos to share?
Tried to attach a picture with my post.
When I selected one from pictures on my PC my screen filled with the picture I selected, but looking to see if it had attached to the post was that nothing had happened. It looks as though pictures can be loaded directly but it just was not happening ! Any ideas as I don't use host sites seeing some of the horror stories with some of them.
