A very sensible approach if i may say so mate :thumb2: ,
As for the static grass applicator,well,they can be quite pricey ..... if i could suggest 2 things?....
1,if you wanna REALLY CHEAP option..... load the base with PVA glue,sprinkle on your static grass and rub a balloon on your shirt
...... yes,i said a BALLOON..... any old cheap party balloon will suffice,the rubbing will statically charge it,hence,when you pass it over your grass it will stand up.... and a bonus is,any of the grass that wasn`t securely fixed will migrate to the balloon and make it easy to rub off and re-use!
2,If you go on YouTube,put in "Static Grass Applicator"..... there are several examples showing you how to make one for just a few quid, admittedly they`re not as powerful as the expensive ones,but as you want to start off with small bases it would be a nice starting item.:thumb2:
Just a thought mind,sorry for rambling on!! :astonished:
Andy
