Horses??? I think we’re talking Dinosaurs.Damn Rick, I never knew horses had wires..............Learn something new every day here..............
It’s why Death stopped using a skeletal steed and got Binky instead: no more need to stop to wire bits back on.I never knew horses had wires..............Learn something new every day here..............
Thanks Steve, the engine was fun, the next section ----- well I'll let you know later :smiling3:A very nicely detailed engine JR. Great work on the tracks. It all looks pretty good mate. Keep it comin
You know what your talking about Paul, I'll leave you and Dude 1 to discuss the finer points :nerd:Looks like a Cat?
Am I having fun ! :smiling: well at least I was warned. Just going to take my time and shout when I get stuck.:thumb2:It's a Jimmy (GMC) 4-banger sent in quantities to Russia in the Lend-Lease Act. These and a whole lot of other things like tanks, armored recon cars, trucks and the like. The engines enabled the factory to start producing these tractors again with little modifications.....
Dude 2, I did warn you about the torsion bar units. Just take your time and glue them in place, unless of course you want to set this puppy on uneven landscape. Nice job on the motor and the tracks Buddy!!! Are you having fun yet???
Dude 1
Neil can't see you having a problem with anything having just witnessed your recent offering. Can't imagine you building a car, thought Horses and Infantry were more your line.Looking good John, makes me feel like digging one of my cars out of the stash... but not yet, too many unfinished projects at the moment:disappointed2:
Hi John
You'll crack the tracks - keep at it :smiling:
Coming along famously John, good job.
Andy.
Yes you did, talk about needing several sets of hands, and small ones too. Going to do a few more track links then wait until I have the wheels on to give me a better idea.Looking good so far, John. I did say the torsion bars were a bit tricky! The knack with the sprockets & idlers is gluing thr right numbers of links together on the bar, allowing to dry for a few minutes, then peeling off whilst still flexible, and forming around the sprocket/idler
John,might not be the correct way of building those torsion bars, but I need to find an easier way.
Dude 1
I done the same on my t55,there where some short rods to use instead of the torsion bars if you want it on flat ground.John,
I have a vague recollection of gluing the swing arms in the correct position, then fudging/fettling the torsion bars to fit - obviously giving any hope of them 'working' - but it's not a flexible track, so maki8ng them moveable seems a bit pointless.....................
That's what I have just done Dave,:thumb2: had to find an easier way, and this is it. Leaving the parts to dry at the mo, all are in correct alinement as per the drawing.Will do the other ends and assemble after I've had a break.John,
Good Lee, can you remember the wiring by any chance:smiling3::smiling3::smiling3:I should’ve known that by the valve cover and the blower intake a thought that looked familiar I learn how to drive trucks on these two cycle engines
Hi Mark, good to know that I'm not alone.The model will be in for repair so should think they would have found some flattish ground.:nerd:I done the same on my t55,there where some short rods to use instead of the torsion bars if you want it on flat ground.
I'll have a look later Rick, soon have the head off !:nerd:The firing order for the straight 4 cyl. 2 stroke is 1-3-4-2.......if it has a 90 degree crank it's 1-4-3-2.......which is your JR? :nerd: Rick H.
John. Diesels don’t have spark plugs. Doesn’t matter on the firing order because there’s no wires to go to the block and no distributor.Good Lee, can you remember the wiring by any chance:smiling3::smiling3::smiling3:
and each pipe has to have the same length!Still, it needs an injector pump and pipes to said injectors.
Andy.
Lee,when I read that I thought good less to do , then Rick , Andy and then Dave shattered my illusions with talk about fuel lines. :smiling3::smiling3::smiling3: Should I put the covers on and forget the engine lol:tongue-out3:John. Diesels don’t have spark plugs. Doesn’t matter on the firing order because there’s no wires to go to the block and no distributor.
OMG! What a great update JR. Coming together really well. Looks a difficult build but your doing a terrific job my friend
