Jim,Hi Mike
That's a very intricate way of going about things but it certainly looks good. I suppose that you'll have to glue some parts solid to prevent it being too fragile.
True, so far if I pay attention to the instructions I have managed to stay out of trouble - now the decorating of the hall and stairs I have to start next week.......Looks like you are having fun with that mate. It is certainly a nicely detailed kit.
You are welcome.That is a kit and a half Mike, enjoy building it and I will enjoy watching it all come together.
Jim.
I know these slow jobs seem to go on forever.YES IM watching too as i love complex kits like this an would build one if i had the time off from my tiger
chris
This is what causes confusion when you have to do that. Probably why I dislike trucks from the point of building them.Update,
So still working on the chassis although there is now paint on it (pics later).
But progress has been made.
I added the suspension locations and made up one of the wheel hubs as a test run...
This is a closer view, these can be added before priming, but I wanted to see how they actually attached and worked...
The suspension rods themselves actually click onto the fittings as seen here, with the wheel hub fitting onto the outer side of the arm....
Test view 1
Test view 2 - they both steer and articulate up and down when fitted - and to be honest the build in this area was getting a bit busy, so went for the seperate items to be constructed later....
And here are all of the suspension arms ready for priming, there are actually four different types of arm, but the instructions are very clear - but you must remember that you are constructing the suspension upside down!!!
As I said the paint is now on the whole chassis and engine, a gloss coat has been added and once totally dry then the weathering will begin in this department. So far now up to page 7 of 13 on the chassis build up....
Chers,
Mike.
Hip hop scrape and paste....:flushed:This is what causes confusion when you have to do that. Probably why I dislike trucks from the point of building them.
Enjoy decorating the hall and stairs :tongue-out3:
Hop .
Apparently the whole cab tilts forward, but in seperate sides, so you can have the one side up at any time - BUT, then there is a large cover over the engine!!! So how much can be seen will be revealed when I get to stage 28 :smiling5:. I do know from watching a couple of YT videos that nothing can be seen from the sides - but you can bet that if I did not paint it......That is definitely a lot more detailed than the Dragon kit :smiling3: Chassis is looking very good, and well-painted. Not sure how much of the engine is going to be visible, though — or does the kit have separate engine panels you can leave open?
I know. I'm like Quasimodo at the moment - running around the house crying "The doors, the doors why do the doors torment me so...." And my Esmarelda replies "You'll get the doors if you do not get on with it...." No sympathy in this house, even the dogs look at me as if it was me did the mess in the middle of the lawn just after she had mowed it...Cracking work so far Mike, and I do mean the Scud not the doors.
Mike , I've sent several, Hop and a Skip needs some doing as well I should think . Yvonne said you are in your element, so much you told her to leave you alone.Non update.
Decorating has taken over so no further updates or work on Scud untill it is finished - how many doors can a house have, I am sure someone is putting in extra ones....
See you all soon.
Mike.
Cheers Paul, the wheels are only on for a dry fit but will be better placed once I have a base ready.Wow, looking outstanding.
