What's on the Bench? 2021
That looks superb Steve :smiling3:
That "Jigsaw" type camo has to be one of the hardest to get to look "right".... And you've certainly more than achieved that mate!
A cracking result to be sure !!
Andy
Up early this morning Mr Smith!! It was certainly a wet one last night. I hope you didn't get flooded out.
The black lines helped a lot tidying it up but it was fun to do, but then I am a masochist :smiling5: :smiling5: :cool: :thumb2:
Yep,up early as the weather was so foul overnight I had to get up and drive Rach to work for her 4:30 am start!! :(
.... Couldn't get back to sleep when I got back!
I see what you're saying about the black lines helping.... it's still a tricky look mind to get mate :)
Andy
Fraid not Paul…..it just takes what it takes. I usually start prep once I’ve started painting the previous bunch. Little and often gets the job done with minimum tediousness……
As well as the small curved scalpel blade (I think it's actually 15, not 15A), fine emery paper and sanding sponges, I've been using the Citadel mouldline remover, which works surprisingly well for some stuff.
I'm starting to realize that, where the line goes through complex detail, it's sometimes better to lose some of that detail in order to remove the line, rather than making an awful mess trying to work around it.
It's still a mighty pain!
You are correct sir. It’s a 15 I use, not a 15a. The image I got when checking was incorrectly labelled :loudly-crying: 15a is a straight bladed version. I have a three sided scraper for cleaning up large white metal castings, but for figures I find a scalpel blade more effective.
Absolutely right. The line jumps out far more than the loss of detail. My pet hate is designers that put the mould line right through the middle of the face along the line of the nose :angry::angry::angry::angry::angry: The Perry Sudan Brits are a classic example. Great sculpts but really stupid mould design on the heads…..I suppose the only up side is that you get proper ears…..
Here's where I'm stumped. Important location, tricky to mask the line with paint, reluctant to lose the wavy hair detail - but it's impossible to get a suitable tool in there! Saw mention of a "micro chisel'' recently - wonder if one of those might help?20211030_141934.jpg
I’d go with a small single fold of 400 grit wet and dry. It should be stiff enough to keep its shape and so work like a very fine round file, leaving you able to remodel the wavy hair if needed…..it should work on the cloak as well…..
1/35 Bradley M2 infantry version. Gulf war 1991. Basic kit Tamiya.
Adding antislip. Base and primer colour is drap olive green (painted before 1991). Regular colour over it will be FS33446 for desert as regulative AR750-1 from this period says (standard sand yellow colour from Desert Storm).
Good work on the Bradley Mak. Up to your usual high standard.
Hi Paul
i mainly use a Scalpel fitted with a number 15A blade, and sometimes some 400 grit wet and dry. The blade is a small curved one that can be used to scrape or cut. I prefer curved blades for scraping because you don’t get surface scratches. Takes about fifteen minutes a figure though….
Tim,
The 15 is the most-used blade in my varied armoury - definitely the most versatile and I'd recommend anybody to add them if not already in possession!
Tim,
The 15A is the most-used blade in my varied armoury - definitely the most versatile and I'd recommend anybody to add them if not already in possession!
Totally agree. I buy them by the hundred……it’s far cheaper. I use unsterile only though, I’m cutting plastic, not skin!
Me too! The lower curve of the blade is also so useful for 'adzing' seam lines on round components!
Now i must make research how really looks non slip under trim vane on front of vehicle. And first layer of desert camouflage is done, especially reason is for better gluing of applied sand.
