It’s been a while, but I’m finally back to this one
After spraying the undercarriage with black primer, I glued the top and bottom together, then began to add a coaming around the hull from etched parts provided in the kit. However, that made me realise I should not have glued the engine cover into the hull yet, but it’s far too late to get that back out again. The reason is that the coaming goes all around the upper hull edge, and the engine cover is supposed to then go inside of that.
The upshot of this was that I had to cut a gap into its front and right side:
It took some trial and error to find a way to do this without damaging the rest of the model (which didn’t quite work, as you can see) but in the end I used an X-Acto No. 13 saw blade:
These fit a standard X-Acto knife handle to turn it into a saw about 2.5 cm long, which is much more controllable than a full-sized saw. It also had the right thickness for the etched coamings, unlike my razor saw which made a cut that was too narrow.
With that done, I could add the coamings on all four sides:
