You make a good point Gerry on the back doors. Both my current and previous Victorian terraced houses have the backdoor facing the neighbour across the wall.Watching with interest.
I'll be the first to admit that I know nothing about London, but do have a little experience of Victorian terraced houses.
Not sure if you've got the back doors in the right place, all of the ones that I've come across are set in the side of the 'scullery' facing next-door, the kitchen is 'outside' from that, then coal shed, then the toilet. But hey, your build and I could well be wrong
That said I do have patio doors on the rear aspect.... Not sure if they were originally a window that has been extended to a door...You make a good point Gerry on the back doors. Both my current and previous Victorian terraced houses have the backdoor facing the neighbour across the wall.
ATB.
Says the resident forum pyromaniac.570 .
Apart from that you can always add burns t o some of the joists to add to the detail and realism.:nerd:
453 .
