How many are you going to build? I like this one but you can build as many as you like I hope to get mine done and start a 1/72 Italeri
Dave. Great kit for my mate P.J. to get his teeth into. Tell him to watch out for those turret grab rails....
Give him my regards and also the best of luck with his build.
Ron
Hi PJ
Good choice of kit. Black plastic - that's a bit unusual (well it is to me anyway) As for the gap, if you do decide to fill it I'd scrounge some plastic strip off granddad. Your little furry helper looks cute but cat hairs in paint ain't good :thinking:
I think (or seem to remember) that the engine deck fits inside the rear plate, not on top of it. These kits were designed to be motorised, with the whole upper hull detachable, and they often fitted like that.
Dave, out of curiosity, I've just opened my kit and had a dry fit.
Seems what P. J has done thus far is correct.
He will need a bit of thin plastic card to fill the gaps though.
I hope you don't mind, but here are a couple of shots, which are better than words which indicates he/you are correct thus far.
First time loose fit, even before cleaning up!
Onwards and upwards P.J. :thumb2:
Going by your pictures and Ron’s, I’d say my memory was wrongI've had a closer look Jakko and everything I see - except for the gaps shown - tells me the deck fits on top and not inside.
Quite probably they had one with the entire kit. Like I said earlier, its’s not exactly known for its accuracy.It's a bit of a mystery as Tamiya is known for their quality of fit - although this one is a bit ancient. Maybe their designers had an off day?
