Tim Marlow
Cheers Lee :thumb2:Looks good Tim
Cheers Rick. Apparently they all fired at the same time :upside: Here is an image of the breech….Got "plenty" guns on this crate Tim.......would be handy if you had to shoot yer way out of the local Pub!! :thumb2: I'm surprised there is no decal sheet...Mfg. oversight? Looking forward to the primer...BTW, Nice Avatar.
If you have an issue with the rules that have been set down and the mods are here to enforce, then please feel free to contact either John or Ian to discuss your problem with them.we wouldn't want to upset the "Mods".
That’s exactly why it failed as a concept Jakko. Two 45mm and a 76mm, with no accuracy. They also tried it with two 76mm, but it wasn’t really any better. The only thing it had in its favour was weight of fire…just like a medieval volley gun :tongue-out3:That just looks weird with those three guns :smiling3: And all firing at the same time sounds like a recipe for missing with some of them, given that the gun types would have different ballistics … But the model is looking great :smiling3:
Thanks GerryComing along nicely
Thanks John. The cleanliness is due to EVA liquid solvent. Applied with a brush, it wicks under joints, leaving little on the surface. The main advantage is that you hold the part in place before adding the glue. I’ve used it, or a near equivalent, Mek Pak, for years. I only use Contacta on joins that may need filling, or those that won’t be seen….I do have Tamiya glues, both normal and extra thin, but have never opened the bottles….might have to try them one day…..Tim .
Very nice , as Andy says " clean " not a spot of over glue in sight.
That was an interesting photo of the breech, imagine crewing that when it fired !
