Hello my friends. :smiling:
There is no shame to show your mistakes.
Below you see how bad it is now.
Let's see if I can make it better.
I will need to put more putty in certain spots as the step is still visible.
I have learned that when you do putty thing, you rather fill up where the step is rather than sanding the step, I ended up with the VERY thin wall in some places and it does tow BAD things.
A. Makes the joint weaker
B. makes the wall thin, some of my redrilled rivets went though
QUESTIONS:
1. What do I do with the rivet holes I made? I assume I need to re-putty them and redo but very lightly, so I do not poke thru the wall, correct?
2. For these rivet holes, do I use Tamiya putty (stronger but dissolves a bit of plastic) or lighter, sanding easier one?
Enjoy by BAD made rivets and HUGE panel lines.
