Have dug this one out of the stash and decided it was high time I got on with it. With the Centurion bridgelayer I will soon be onto the bridge and constructing 8 sides all the same plus all those rivets and bolts will soon drive anyone to the rubber room. So to run along side it and swapping from one to the other I can keep a modicum of sanity... Yes I know Sanity Claus etc etc.....
So here we go...
To start with this is a full blown resin and etched brass kit and will require a certain amount of experience - not to build the kit but to identify parts, correlate them to the miniature photo instructions and hope you have got the correct part in the correct place as Accurate Armour instructions leave a lot to be desired, as those who can remember my Chieftain bridgelayer build it was a case of open box - throw away contents.... Let's hope this will not be the same.
Starting with the chassis front suspension - you have to clean up the engine first, add filler to the bottom of the sump and clean up - clean up is a word you will get tired of on here.... BUT, later you will be required to fit the engine from the underside of the chassis and then to paint it a shade of Robins Egg Blue - and at a later stage paint the chassis Green.... So I went the other way and cut away the cross member/engine location from the engine itself, and scratch built a new cross member on the chassis. This has now allowed me to fit the engine after the chassis is painted.
As you can see I have progressed with the front susspension and steering arms and brake back plates, again cut from their sprues and clean up. I did find that there was a crossing of the part numbers for the brake cylinders and some confusion about where the steering links from the power steering were located on the back of the brake back plates. These (part 14) fit in the centre of the back plate where on the instructions the numbers 5&6 are, but the way it reads is that it is the steering link that goes there.
So all in all it took about three hours to get to where I am now...
I have still got the add the steering link and the other link for the right side of the pwer steering shaft and links. A close look at the chassis you will see there was plenty of cleaning upp to do - in fact so much that at one time I considered scratchbuildin a new one - but we shall see how this goes.The wheels by the way are just dry fitting.
More later
Mike
So here we go...
More later
Mike
