Decal removal
The Smythe Meister
Devon, England
Mornin'
As the title suggests I'm after a proven method for getting a decal off a model, without causing too much damage to the surface beneath.
Any ideas would be much appreciated chaps :)
I can't help Andy but I imagine that if you've put a coat of sealing varnish over the decal it becomes very much harder. I'll be interested in the replies.
With decals that adhere well, the only reliable method I’ve so far found is scraping with a knife … but that kind of goes against the “without causing too much damage” requirement :(
Hi Jim,
I haven't used varnish over it yet.... Only Micro set,so fingers crossed!
With decals that adhere well, the only reliable method I’ve so far found is scraping with a knife … but that kind of goes against the “without causing too much damage” requirement :sad:
Cheers Jakko,
It might come to that if no other method comes to light......
..... The bloody thing has to come off one way or another!! ;)
According to the bottle, Mr. Smiff, Micro Set can also be used for decal removal. Might be worth a try Andy...
Have you tried using a pin to gently prick the decal several times and then brushing more Micro Set on it? The only other idea would be sandblasting it off, but that is rather extreme...
..... the more I think about it,the more appealing sandblasting the ruddy thing gets!! ;)
Get behind me Satan....
..... Spent enough on this hobby the past few days as it is you bad,bad man!! ;)
Yeah, like you're not already thinking it..........."Pet I bought the wrong colour of green for this model, so now i need to buy a model that is this green so I don't waste the paint."...............
