Afternoon, yet another of my mind numbing reviews, remember my opinion!
Picked up a bottle as i wanted to compare against Mr Color lacquer
Like Tamiya it say acrylic but it's not
I had read that it has virtually the same ingredients as Tamiya and the smell is very similar to Tamiya, not unpleasant and certainly a lot better than Mr Color!
Tried on 2 plastic spoons, one not primed and the other primed with my favourite Mr Surfacer 1500, grey and thinned as usual to 50/50 with Mr Color levelling thinner. Sprayed 2 thin coats at 18 psi.
Not sure if the dedicated Aqueous thinner smells as strong as the lacquer thinner or is less pongy. But I have full bottle of thinner and Tamiya lacquer thinner to use up. However will get a bottle to use and then use up the lacquer thinners to clean the airbrush, will save on buying liquid reamer!
The one on the left is unprimed, you can see a clear difference between the spoons, the right hand spoon is primed and has a richer darker finish.
I dried with a hair dryer then applied Mr Color lacquer varnish.
I read that there's no problem using the lacquer thinners, paint, or varnish and they are correct, perfect, no issues.
Very, very impressed, sprayed so well just like Mr Color. Dried well lovely smooth finish. Big reduction in the smell but like Tamiya smells a bit.
Will look to switch to this.
Hope you are well asleep by now lol
