Just trying to help, Allan.
John.
Very much appreciated John, Thanks again...
Great stuff with those shell cases Allen. Real good problem solving.
Thanks very much Jim. It was time consuming, but they're finished now...
Thanks Paul, but I didn't realize it was an actual SBS when I wrote the post. I guess it wouldn't do you much good in your scale though my friend...
I have been doing quite a bit on this of late and sorry for the late replies. I have found that one just can't sit at the table the whole day and play. Rather unhealthy I'm afraid. I have taken this month off from work as things are rather slow this time of year, so I take walks and ride my bike to get some exercise between bouts at the table. Now, moving along, we finished the shell casings,
I have no idea what to do with the left-over warheads though. In total we have 48 so far. If I do need more, then I have another 48 as backup. I then finished up the turret. I glued the muzzle brake back onto the barrel after I got it as round as I could with the scraper. Then glued it all together, added the lifting hooks and scratched a cupola cover for the turret,
The normal drum cupola was stripped off including periscopes and the parts were used for repairs on other battle worthy Panthers elsewhere in the Reich. To finish off the Panther, I added the tool/equipment holders that were welded on the hull, but stripped of all their tools,
And on the other side,
Of course, you won't be able to see them once the hull is buried in the street, but they were there,
For Reference Only
With the Panther done, it was time to plan out the street section. I had some blue foam in the stash that I bought at the Euro in 2016, but never used. I figured I could scribe the cobble stones into it and didn't have to be too large in size. I ended up having to use two thickness' as there was only one sheet of each in the pack of 4-6mm. No problem as 1mm isn't a big deal in size. I now give you a top-secret German weapon. The "SchwimmPanther",
Ok, Panther's never did swim!!! This size allows me to build up the dirt and cobble stones, scatter the shell casings and not have it too large in scale. It's not set in stone yet and I may change it a bit. Another view,
The chassis will sit a bit deeper as this is just a test fit. Now it was time to move forward...
I woke up yesterday and decided to get stoned...No, not that stuff we did way back when...Cobble stones folks. I knew I would need quite a few and I had the plan,
Cut the strips @ 0.5mm and chopped them off @ 0.8mm length. The leftovers would be used too as these were different lengths to fill the odd spaces. I made 20 strips and after chopping them up, I had about 300 cobbles. Looking at the reference pics to see how they were placed, I noticed something odd. The damn cobbles were twice as big in diameter as the shells. Huh!!! Wrong thickness of foam used!!! We are building a street scene here, not the Reichstag. Time to get stoned again!!! Using smaller thickness foam and an hour or two later, we had them done,
The big Reichstag blocks on the left and the real street cobbles on the right. You can really see the difference between the two. I think there are about 400 in the plastic bowl to use around the tank. Next up will be designing a base for the dio and then scribing the cobbles into the foam sheet around the tank......
It's ice cold here and the temps don't go above -2° the whole day. Nights are -12° or more. I just love winter. Thanks again for looking in and I hope to have an update soon. Have a good Wednesday and stay warm folks...
Allen
