Double Dakota
I'm gonna loiter around the back of the room ..(I'll be keeping an eye out for matron wearing her parachute)... I've always wanted to build a Dak but never got around to it...
Cover my back Chris :smiling:
More progress on the double build. The cockpit decals need modifying to fit correctly and not happy with how the crews sit, they are probably a generic pilot and come complete with parachute and this I think is the problem. I'll butcher there rear ends and re seat them. Managed to get the inside of one fuselage also painted before having to head to work.
Progress is continuing with the builds. Nemesis time, the dreaded seams. I started with mine first, both halves went together ok but whenever I lined up the top the bottom was out and vice versa. I spent ages trying to get the best fit. There also seemed to be a dip running both sides of the top seam, I just set off trying to sort it but decided to check aircraft 2 before getting too far. Unsurprisingly there it was again. I need to try and find a roof pic now while I continue the buttoning up.
Damn that looks a bit much Mick, no doubt a twist in the body .Sure you'll sort it .
We're lucky enough to have the Dakota fly quite often around here as it goes home to its base. Looks really good when it does a fly by with the door open and a crew member standing in the door .
Not good Mick! Are these an older kit?
Not sure Andrew, new style boxes but no idea, I’m sure one of our more learned members will know
I’m not giving in JR, I was spoilt a bit with the F-16
For such a new kit the seam problem shouldn't be as bad as that. You'll sort it, I'm sure, but a lot of filling and rescribing.
The rescribing isn’ Straight forward either Jim as several of the panel lines that cross the roof don’t join up. I’ll chuck some undercoat on and see what it looks like
Mick,
Seams are a pain mate. What filler are you using?
I have a mixture, Vallejo for open seams and Humbrol for jobs that need sanding, even got some Mr Surfacer. Just a pain that what’s bad on one isn’t on the other, the fight is on
Fight the good fight Mick. :)
Seams.... Hmmm, that's what put me off building planes all those years ago :( ..... Luckily mind,since my return to them recently,in 1/48, I've not really had an issue with them...
.... not much of a help to you.....
..... but it makes me feel better!! ;)
Good stuff though mate, you'll crack it and get a great result in the end I'm sure. :)
Sounds like one of the problems I had with that awful Revell Mosquito. :sad:
I don’t remember this kit being naughty for me, having said that I sometimes stand at the top of the stairs wondering why I’m here.
Too late now, but I wonder if the left side of one would have fitted the right side of the other better.
Good luck with this Mick only reinforces why I pull wingy boxes from the stash the put em back again. Just for now I'll stick with the mud covered defects. Dave
