Simon's Mandalorian Razor Crest, Revell 1/72
No afraid not, grodu i think his name is… cant find one that scale either to stick in unless someone can print one :rolling:
TBH, all you probably really need is to take a bit of plastic rod, round off the top, stick two ears on and paint it :)
Sorry for the delay in any updates i have managed to assemble the inner hull of the ship
along with the ceiling and cockpit floor same thing!!!
Wiring is for the rear cockpit space
in place but not fixed yet
Then this all fits snugly in the main fuselage shell, but i need to give the door openings a quick coat of paint as i suspect these areas will be seen when assembled
lastly i have trial fitted the engine component's
thats about as far on as i am, I’m waiting to solder up the internal led for the engine (copied from you tube build) once i get the cable for it but it looks the dogs ##s. Detail and fit is really really good, i am enjoying this build So much more than i though
more as and when i can get going,
simon
Well quite pleased with this effort this was a trial of my led truster (no idea how to add a small video) image.jpg
That looks very convincing. As you say you want to show a video of it, does it flicker?
Hi Simon,
I’m interested to know more about the LED’s and power source you are using on this kit. What do you used etc.
I just got this kit myself and I’m interested in doing something similar.
Thanks n
Hi Simon,
Thanks n
hi
basically i stripped down 10 led Tee lights, using one of the tee light casings i driled 4 additional holes around the out side and glued the leds in to these holes then i solder them together, you need to check the polarities on the leds, the bulbs have 1 short leg and one long leg -+ then you need to solder the all the positives together and leave a long length of cable to feed through the craft, repate for the negitve side, test before glueing together i used short lengths of computer cable to link all the bulbs & power is just 1 x 3 volt battery per unit or for both
you also need to cut away the outer rims on the truster and drill out the slots as well to allow the light through up side is the whole assembly fits nicly in to the cavity in the engine although i used some foam to take up the play glue gun or rubber would work as well to keep them central
i have some other pictures i will post later
led's i bought 20 or so for a couple of quid from Amazon
any question let me know is easy
simon
well at long last made it to the model room …
1st of, the engine parts with the holes drilled and the fins cut down, drilling the slotted holes was tricky but not hard cleaded up with a scalpel then i cut down the outter fins using a razor saw and scribed the inner side with a scalpel & broke them off again cleaned up the ragged edges lastly i drilled the centre hole. Before and after picture below there is an ailinment notch but its not really required.2D4D54C8-66A5-4E00-8635-F53A8B91D37A.jpeg
i have now put the inner cabin in the hull along with the doors these all fitted and work well with very little fettling or cleaning
then i noticed its really dark in the cargo bay and all that detail is lost in the gloom so i popped a couple of holes in the ceiling and light it up
luckily therebis loads of room for the wiring so i decided to add the battery pack to this area as well and i will add a switch to the rear cargo door area once it arrives. E966F0E6-9F83-4E16-93E7-525D2121755E.jpeg
so after this i tested all the bulbs and my ruff wiring lay out and .. bugger me it all worked
Ok top of the craft i have primed no pictures yet but i will press on over the weekend see where i get looks like rain so no garden duties or bike riding
simon
That looks good, and yeah, if you’re adding lights anyway, you might as well stick some more in to illuminate dark areas :)
I take it the battery pack will be accessible so you can change them when they run out?
That looks good, and yeah, if you’re adding lights anyway, you might as well stick some more in to illuminate dark areas :smiling3:
Put in 3 x 2032’s cell battery‘s, the ones in my shack have lasted about 3 years, but once these run down it will be game over, not they will be used much short sighted i know but they draw little power so whats to loose !,,
latest I have masked up the windows and primed the fuselage along with the trusters and landing gear, hope to respray Sunday with black primer and then silver topcoat.8926F04D-FAC1-46F6-9B2B-37C2E48FE97E.jpeg38ACB3A0-C740-4D67-B596-434A307D98E4.jpeg99D1683E-AE85-49B4-93F3-56AE79EF19B8.jpegAA39819F-8C09-4237-9138-DE406BA22EDD.jpeg6882C176-B4DA-41C4-AEED-2729F2538DC1.jpeg8B28E36F-F180-4C98-80D5-7E55295733DE.jpegB9461EB3-7ADC-4C8A-B266-F02FC358F3D3.jpeg97F3CBE4-14CB-454A-9F27-4E4C96E76020.jpeg
As promised she is now black … been awhile since i airbrushed this big a kit but turnded out quite well still in the booth and left to drying out over night
so im off to watch the bsb moto gp racing was great if anyone managed to catch it ..
simon
little up date she’s now silver and the engine trusters exhausts are painted but this is my first attempt and not sure im happy with them 4A6C9A23-AA9A-4287-A7D8-7A012D40DFBC.jpeg31316200-5A4E-426E-BC12-9C2137F42641.jpeg9A50ABAC-A0BB-4B46-AF21-5BF4CAD5F76F.jpeg8C3C682F-EE13-4F14-982B-647E454E625F.jpeg9FAC6604-9C93-4E38-9A3B-DD83D31D0750.jpeg
evening all.. well this coming together now hope to be compleat by the weekend fingers crossed, so I have added the decals no issues at all, and panel lined some not all of the craft theres a lot to do and also added some weathering badly if im honest
73AB1F9D-992C-4A80-98B4-E75A19BB48FB.jpegA1603C73-38EF-4EA7-8811-3D5C26C7AF9C.jpeg4591BACE-FBF2-4ABB-8AF7-368C056720A6.jpegD13E1011-6A20-42D1-A207-103B2DA5E016.jpeg6EE22873-F59B-4D42-8334-FB40D50710D1.jpeg
simon
