Yup, you answered my queries thank you Chris. Just curious, as I had a job at Sunseekers watching huge Tupperware motor yachts being built. So trying to sort out the differences. Quite ingenious - paint first then layer after layer of F/G. Mind you some of the tolerances would never have stood muster in the aviation business!!!!WELL Doug yes the insides of the hull is white gloss paint over F/G mattin as when painted in white its easy to see if a wire has come adrift or any thing eles that not suppose to be in there like lose screw or such
an its also easy to spot if a crack appears in the hull as i build mine strong but it can happen an no the motors an eletrics are mounted up on half an inch of wood mounts hows that eh does that answer your qurstion s Doug ?
chrisb
