McFarlane space marine
Ancientmariner
So I've been looking at Warhammer 40k for a while as I fancied doing something as I used to do it as a kid.
After looking at the site one or two things grabbed my attention but in an unrelated search I came up with this, an unpainted marine whose about 8 inches high standing.
Detail and moulding is good and I just thought it would make a cool thing to go on the shelf in the shed when it's done as a dark angel.
Base undercoat of grey (looks more white to me) is done, will then spray with black undercoat tomorrow and then start top coating.
So finally I have found a pot of enthusiasm and got on with it......
Base coat done, time for detail and weathering!
Also the dark angles scheme went by the wayside as the imperial fiat I think looks better this time.
Also given up trying to airbrush acrlyic paints, lacquer based are just so much easier!
Very nice indeed. Shouldn't this be in the Figures section?
So something I missed. Between undercoat and painting I actually completely stripped the model into component parts and base coated.
Shocking to see that it's almost two years but finally completed. Need to speed up a lot!
It's not great but it's ok, my photos also aren't great.
IMG_20230507_151020.jpgIMG_20230507_151012.jpgIMG_20230507_151001.jpgIMG_20230507_150948.jpgIMG_20230507_150941.jpgIMG_20230507_150934.jpgIMG_20230507_150927.jpgIMG_20230507_150917.jpgIMG_20230507_150850.jpg
Just finished one too, mine is an ultramarine. Not the easiest things to paint. Nice work
Did you fully disassemble? I did when I repainted it. Really need a heat gun or hair dryer though to make stripping apart easier I found
Took most of it apart, left it sitting in hot water initially then a mixture of hairdryer and Vaseline to put it back together
