Rick and Colin. Great comments. Thanks fellas. :thumb2:
Rick. I really should offer Idu some work. Very soon perhaps.
Colin. A piece of slate makes an excellent base to show models on - even if only temporarily.
As I was in the shed doing some background painting for 'Omaha', I thought it a good opportunity to remain in said place and throw me some powder and water around on this base.
I'm going to try and model a heavy sea, rather than an all over the place one...or summat in between! Best just see what develops. :upside:
Here's progress thus far.....
I've stared by sticking together two bits of scrap polystyrene. I then sloshed on some thinned P.V.A. and let dry.
For shaping the sea, I always use whatever is in the shed. Preferably powder based. This one is done with some semi hard filler I found on the shelf. A bit of crushing with a paint scraper and it's near enough for this job. I've never used resins and other bought 'Water' stuff. I don't see the point.
To each his own, mind. It's what the modeller is happy with that counts, not how the result is obtained.
Here's some pictures.
The sea doesn't look rough just yet, but Enterprise is
well bows down and ar*e up!
The carrier's wake is added.
Don't worry if your mix gets on the hull. And certainly don't worry about any wayward lumps and bumps, it all adds to the fun! These will be sorted out later.....
The props wake.
....and the angle of the dangle!
Once 'ard enough, I'll smooth things out a tad and add an all over coat of some shade of blue/green.
Cheers.
Ron
