It’s area, the area of resin being displaced when the plate lifts is relatively small compared to the big machines so yes, it still happens just the same but the areas are so small it doesn’t matter and you get away with it. Same thing with the FEP flexing and lifting, you don’t notice on a small machine, the prints fail on the larger ones.So the cold causes less of a problem with the resin feed on the smaller Mars 2? I would have thought smaller volumes in the reservoir would be more prone to cold temperature issues?
I get it now. I was thinking of flow from the reservoir, not over the build plate area. Thanks Nick.I didn’t explain that very well.
As the build plate lifts, it forms a vacuum/suction with the previous layer, and when this breaks with the lift, the resin has to flow back into the void created so it has to travel from the edges of the plate back to the centre, even when it’s cold and thick, the time this takes on a small printer is always less than the combined, lift, dwell (if you have it set) return time as it’s never very far back to the middle.
As you get bigger build plates, the time this flow back takes to happen as the distances are further, is longer. When it gets longer than the time the lift, dwell, drop cycle takes, that’s when you get problems. So you can either wait - add dwell time, which slows your already slow printing down, or heat the resin to make it flow quicker, or some combination of both.
I’m interested in repeatability above all, so I fix my resin temperature and test it completely, so when I do get failures I know it’s not that. Believe me, there are plenty of other reasons your prints fail so eliminating just one factor is a major advantage.
This is the trouble, there’s so much witchcraft and nonsense out there it’s knowing what to believe because obviously you can’t actually see any of this happening and have to try and figure out what’s happening yourself looking at a failed print.I get it now. I was thinking of flow from the reservoir, not over the build plate area. Thanks Nick.
My ten penneth having done a bit, is to stump up for a wash/curer unit as well as printer day one as offered in your bundle. I personally consider this essential now for modelling anything with detail. Also, the cleanup is the most off putting part when you’re starting out.
The resin is nasty stuff and gets everywhere and sticks! The biggest mess is manual cleanup. A proper washer unit makes 99% of this go away and ensures all the resin is cleared out of all the nooks and crannies of detail it otherwise wouldn’t be. Mainly though, you are more likely to continue. I nearly gave up before I got my first washer then everything changed and I never looked back.
Be aware the technology is moving quickly and honestly, I think 3D resin printers are the biggest bargain in the world if you look at the cost vs what they can do. You want monochrome, not colour, which sounds counterintuitive but isn’t. So the opposite of tellys if you’re old enough to remember B&W :smiling3:.
4K is a minimum now for a small printer, 8k for larger and the newer machines are 5 or 6 times quicker than the older ones.
You can get a brand new Mars 2 pro for 200 quid which is broadly equivalent to the machine you’re looking at. The screens and UV light sources have a life as well, so you won’t know how many hours it’s got on it, and you don’t want to be swapping screens out in your first steps really. So personally I would always choose a new machine every time.
You’ll end with more than one anyway most likely. I did!
Don’t worry about light. The machines all have uv covers, I often leave resin in mine for long periods, you shouldn’t really but it’s never been a problem in my experience.
Also my advice would be don’t be tempted by the larger machines to start with, they are orders of magnitude more difficult to get working reliably and I’m still grappling with some of mine now a year after acquiring them. I won’t bore you, but they don’t scale well, things that work on a small printer will often fail on a big printer for various reasons I am slowly coming to understand.
All my filament stuff has been in the loft for years, I never used it either. I resin print most days now. It’s night and day between the two technologies for us modellers IMHO.
Erm, I’ve got the airbrush thing too. My kit was built up over many years, with the CNC Carvera as the latest piece.My first thought was "That looks like a huge capital investment" - including your new milling m/c. Then I thought, there are quite a few guys on here who have workbench and airbrush/paint set-ups which cost many hundreds of pounds, so maybe your investment isn't so huge in comparison.
Any chance of a quick 'essentials list' including any 'puter programs etc? I doubt whether it's the kind of thing I'd do, but there are sure to be some guys on the forum who might be interested.
Nick,There’s some things that can help with PCs - I used to be head of technology for a large global company BTW so this isn’t ‘bloke in the pub said…’ advice.
If your motherboard will take it and most recent ones do, buy an M.2 SSD drive, it doesn’t need to be big, 500GB is more than sufficient.
Boot from and install windows on this - just windows. Put all your other stuff, files etc on your existing hard drive. You don't even really need to remove windows from the old drive yet if you're nervous, just point to the M.2 as your boot drive and dont touch your old one, leave it connected as it is and you will still see all your existing content.
This will do 2 or 3 things - M2 is orders of magnitude faster than standard SSDs and leaves mechanical spinny disks for dead so your boot up time will reduce dramatically straight away.
But also it will allow you to flatten windows every 3 months or so (I do it about this often) very easily and quickly without affecting your other stuff.
All windows versions slow down over time and reinstalling regularly, fixes this.
All the so called tune-up stuff you can buy doesn’t do a great deal and I personally wouldn’t bother.
Do this instead. It’s far more effective.
Don’t install Norton or any of the mainstream anti virus stuff either, it’s all bloaty beyond belief and hammers your machine performance more than anything else.
Avast or AVG anti virus are probably the least impacting. You can’t uninstall Norton etc properly either by the way, it leaves hooks and junk. Either, don’t install it in the first place or re-install windows to get rid of it properly.
And yes, RAM is good, get more if you can. If you can't, again M2 works at RAM speed (more or less) so even if you are paging due to lack of memory this makes it a hell of a lot better.
These things will give you typically 20% to 40% performance boost for little or no outlay and a bit of effort.
M.2 has been around since 2012 the same year windows 8 was introduced. M.2 slots are often the most overlooked slot people don't know they have. That said, if your machine is 10+ years old, you can't really expect it run modern CAD properly. What exactly is it, and I can check if you want.Nick,
M2 SSD memory? my machine was updated to Windows 10 from 8 - small form factor - I can't add anything to it - it's not upgradeable in any meaningful form! It even has a DVD writer - I can't remember the last time I used that!
