Brick wall from styrofoam
StephenN
Hi folks, just started building brick wall from styrofoam. Started on 7th May.IMG20230507112246.jpgIMG20230507120208.jpgIMG20230507120208.jpgIMG20230507120205.jpg
Good job Stephen, will you be adding texture to the surface and irregular dinks on the individual bricks? You can usually press a rough stone to get the surface texture.
Wabble
Here's an example of what I managed to achieve with the rough stone and scalpel.
The bricks appear to be uneven and not flat. Painting will enhance it further.
Wabble
Looks good. Another way to add texture is to use a screwed up ball of kitchen foil.
Wabble
Hi Wabble, Thank you, yes, I will be.......in fact, I already have tried, I just need to make it more obvious!! Thank you so much for the advice on texturing, trying to rough-it-up a bit!! I will keep going. I've already been trying on more styrofoam walls!! Will keep going. Speak soon!
