Tamiya 1/48 challenger 2
The paints arrived for this so did a couple of test blobs. Mr color deck tan & sandy yellow, real colours rc040 light stone.
I ended up plumping for the real colours. It's come out a bit yellow in the pictures but I'm happy with it IRL.
This is the first time I've used the real colours and I'm impressed. It reduced nicely with my usual mr color leveling thinner and sprayed very well. Definitely a range I'll use again if I need a colour I can't get in my normal line.
Thanks mate. I'll let it sit overnight then crack on with some of the details.
Thanks Andrew.
3 builds on the go is definitely a record for me. I'm enjoying this one so much that the diorama is falling behind though :confused:
Thanks again everyone.
There's a lot less parts to throw together on this version Doug. :smiling5:
Restarted mine today after a wait for new glasses. After some 16 minuscule handles, PE windscreen wipers about 3mm long and less than a mil wide on the drivers viewing port it tested my new specs no end.
Your making good progress I see. :thumb2:
After finishing the Ki-61 I've jumped back onto this. A pin wash and a bit of detail painting has been done, the decals were added, then it's been given a coat of satin varnish. Running gear & tracks are now glued in place but the upper hull & side skirts are still dry fitted.
A note to anyone that builds this in the future - I was having a hell of a job getting the turret to go on but simply scraping the paint from the mounting ring had it fitting perfectly again. Shows how tight the tolerances are!
I was going to ask for a seat, but seeing how quickly your done this I'll just stand . Very nice indeed mate .
Some going Andy. Nice work too. Mine is still WIP I'm afraid. SWIMBO has me running ragged this week. So no bench time at all!!
I had similar problem fitting the turret. I cured mine by filing the tag on the turret that slots into the hull cut outs. Probably only a thou or two but it makes a difference!!
Thank you all.
There's still a bit more work to do John so make yourself comfy. A camo uniform on the 1/48 figure will be a new one for me.
Work is very quiet at the moment Doug so I'm lucky to get plenty of time at the bench.
That is looking very nice. I was having some doubts about how light you made the IFF panels, but they do seem to have been almost offwhite on British vehicles.
Wow Andy, I thought maybe you had retired!!! With so many builds going on at one time, I can't keep up with you Sir...I love the paint finish on this and the clean and tidy work all around. I gotta go find your wing thingy now and give you a hard time. LOL!!!
Allen
Thanks Jakko.
The instructions would have you paint them in X-2, even brighter!
In the end I used some AK Off White toned down a bit further with their Iraqi Sand.
Ha, you aren't far off the truth there Allen! We're winding down the business as the other partner wants to spend more time with his family and new baby.
I'm trying to add up if I can manage early retirement but keep running out of fingers & toes. :smiling5:
I've weighted several models so they would set into the gardening better & noticed they didn't get knocked around the bench while being worked on. An unexpected plus.
Looking at photos, plain white would be too much, I agree. They already draw attention immediately as it is — maybe that’s why the British vehicles had them in almost-white? Bit odd, of course, but hey …
This one is now finished. Apart from the tow ropes that is, but they look terrible so will hide inside its belly :smiling5:
I made a couple of boo-boos during final assembly but luckily they aren't too noticeable
Your paint work is as expected just perfection Andy .Love the figure as well , very good skin colours
