Hi guys, well! I did manage to get through a few sections today, better than I hoped.
Mounted the (insert own expletive), machine gun and a few odds and ends, grenade launchers with accompanying PE! The antenna platform is now in place. (Two handed!! Mike but only just) Sneaky - those legs. The forward leg is a tad shorter than the rear legs!! (I surprised myself by noticing!! Awarded myself a cuppa for that one!! :rolling:
I deliberately kept a piece of PE back as it fits over the lens part on the left of the MG. Figured it may well make painting later on a tad more difficult!
Next up was the fitting the hatch cover over what I assume is the commanders position. (Should have paid more attention at Bovington).
Main gun mount thingumy:flushed: was also attached.
Similar pic but hatch closed!!
Bottom of turret was fitted and then after another cuppa - mounted on the hull.
Even if I say so myself - it's starting to look like a tank!!
Silly ole SWIMBO says 'Oh you've nearly finished then'!!! At that point I showed her the rest of the bits that still need fitting!!
"Ahhhhh" say she!! You'll be a while then!
Won't be working on it the next few days but will be popping in as I'm on dog sitting duties now post surgery.
