Scotties GMC CCKW 352 1/35
A little bit done on the cab, not to much but as the cupola is open and I may have a door open as well. Mainly just fixings on the floor plates.
Then the detail around the rear window. In the corners of the cab were some really bad injector marks but hopefully they look better now.
cheers
Scottie
Marvellous how just a few screw/rivet heads can make such a difference
Great stuff Scottie. Ejector pin marks on the inside of curves is one of my pet hates. Sanding/scraping, whether filler or raised plastic, is a real pain.
Jim, your right and it seems the harder they are to get to the deeper they are.
Circle plug master cylinder access? Great job so far.
Added the piping around the seat cushions with some copper wire. I didn't want them perfectly straight as I am trying to show the dents in the seat from use.
Then the etch screen was added to the cab's rear window and the cupola was added.
I have also added some details to the cab doors will post some pictures later.
Scottie
The cab needs to be assembled now. So prior to that I have detailed the inside. My intention is to have one door open but I have decided to keep the bonnet closed.
The inside of the doors have a few additions and have been painted.
I didn't want it to dirty just lived in.
cheers
Scottie
A real first class job on the cab. Great weathering on the floor and seats.
