The model is now finished:
View attachment 491658View attachment 491659View attachment 491660View attachment 491661View attachment 491662
The holders for the framework of the canvas tilt were not too bad after all. I annealed them with a cigarette lighter while they were still on the fret and then bent them around a piece of thin steel tubing. That went reasonably well, but I think that for a future kit I’ll look for material that’s easier to bend than brass.
The grille over the exhaust is still loose, as are the seats and the driver, and the windscreen wipers are also to be attached, all to ease painting. There are three parts I didn’t install: the cable between the two parts of the radio, because it pinged away and I couldn’t find it anymore, and two etched parts (TP12 and TP13) that go inside the grille at the front. It’s totally unclear from the instructions where and how these actually go, but this photo shows them well (in the yellow circles):
(source)
The reason I skipped them is because they’re etched parts of about 3 mm long and 0.5 mm wide, with a section of under 0.5 × 0.5 mm that has to be folded over at right angles to the main part. I gave up trying to do that after a while. Because I’ve wanted to build the model straight from the box, I didn’t replace them by plastic strip, which I would if I were building this “for real”
And because I was taking pictures of the completed model, I dug up my part-built LZ M29C for some quick comparison shots:
View attachment 491665View attachment 491664View attachment 491663
I still need to hold a ruler or calipers to them, but at first sight their dimensions seem to be quite close.
(source)
