Warrior IFV with a few bits added
Question - why this reply twice ????
I wondered about that too. First I thought you had forgotten you had already posted something in the same vein, but then I compared the two and they’re word for word identical, so I figured you hadn’t posted it twice yourself. Some kind of glitch in the forum, I guess? Maybe because John’s tinkering with stuff to facilitate changing it to different software in a while?
Update,
So a bit more work done on the hull and more work carried out on the turret...
Testing the turret turntable for fit....
The innards of the turret with the seats in the background still to be added, plus smaller handles etc..
The replacement Rarden barrel...
And a dry run to see if it fits...
And then it will be on to this....
With these.....
Mike.
You must really love bar armour, given how many models you build that have it :)
You must really love bar armour, given how many models you build that have it :smiling3:
It's only three completed up to now, hope this illness cures soon... But there is a LAV-III with bar armour..... (not in my stash - yet!)
Update,
Sorry Jakko, forgot I had this one in the stash....
Anyway back to the build...
I started off adding the turret periscopes, and after cutting them off the sprue further inspection revealed they would be a lot of work...
So the second option was to use the etch ones but I got a problem of the very thin lens/front not bending true and flat.
So the final option was to scratch build my own, but I would use the etch covers...
So the 'periscope part was cut from the cover part and discarded. The cover was then bent to shape and attached to the turret.
The 'gaps you can see are in fact filled with c/a and once dry sanded to shape as were the scratch periscopes...
I have also been working on the large front sights and added those...
Just a bit of cleaning up required ready for the mesh screen later in the painting.
The headlights have also had some attention paid to them - I bored out the plastic front and after painting the inside 'Chrome Silver' I will add the light bulb and lens.
And finally here are a couple of pics to show the progress so far....
Mike.
Update,
So moving on, still finding little bits that need to go onto the model, but these are done during a break from the etch work - talking of which.....
Here is the first fret (parts taken off) and you will notice that it is labelled with the area (Hull Right) you are going to build.....
To make life a bit easier I did enlarge the illustration from the instructions and make notes of what I had to build...
This is the outside frame that once bent to shape the slats will be fitted into...
So while that was drying, I chose to use c/a for this job as opposed to soldering (too idle to get the soldering gear out) and I did extend the 'tab' that you cut to seperate the part from the fret and made that into an 'L' shape so that it would hold the junction of the two ends together. I will try and get a closeup of this later.
So while this is drying I cut out and cleaned up the slats and also the rods allowing about 5mm extra on the length to aid with the glueing.
And here is the part during the construction. I usually work on an old floor tile scrounged from my neighbour, with two cheap 6 inch rulers cemented at a 90 degree angle and small metal blocks to hold the parts square. Here you can see that a couple of the slats look bent - that is common and they will straighten up as the build progresses.
The join for the frame is at the top left, I then put in the top two slats and cement them in place, then the bottom two slats and c/a them into place, with the rest of the slats inserted alternativly top and bottom finishing with the centre two. Make sure that the holes are all aligned before cementing, this can be done by eye or using a bit of the rod.
Once you are happy the rods can be inserted and cemented in place.
To add the cement I use the tip of a No10A scalpel blade dipped in the c/a and find I can control the amount of c/a touched to the junction of the frame and slat or slat and rod.
Once you have the frame completed DO NOT try and pick it up as some of the c/a will have gone onto the tile, here you slide a single sided razor blade under the edge and gently lift the whole frame away. and then you can do any cleaning up, trimming of the rods leaving a slight bit of the rod above the frame. I usually run a line of c/a down the outside edge of the frame to seal the slats and once dry give a light sand to smooth out the job.
And here is the finished item, you are looking at the side that is c/a'd which will give you an idea of how much is used. Take your time and take a break every so often - it helps.
Mike
Update,
Paul, Mick, John, Andy, Neil and Paul.
Many thanks for your comments.
OK as stated last time I said I would put up a pic of the frame end...
This is the best I can do and enlarged through Photoshop. The top pic shows the extra that is left when you cut the fram from the fret. And the lower pic shows the bend made to hook onto the frame end.
And here are the first six frames, making up three full frames in place. Still more to do.
Mike
Update,
Panels 6 & 7 still on the bench waiting to be cleaned up. Had a slight accident with the first panel where I leaned on the lower part a bit to heavily and snapped the resin connecting plates. So luckily they hung on by a thread and I was able to c/a the join. But the result is that I will now be replacing these with aluminium strip dressed up with nut and bolt heads also there are some round connectors which will be replaced (more later) for panel 8.
Here is the mini-bench with work in progress...
20231016_153646_HDR.jpg That is frame 7 jigged up and ready for the slats. Above that you can see frame 6 drying and to the left of that the new connecting plates before detailing.
Mike.
Update,
Mike
Excuse my language but bl**dy hell, that's something else!!
