- Joined
- Jan 26, 2017
- Messages
- 2,692
I used those paints and the result was nice: thinned with its own thinner, easy to spray, give a smooth and a semi matt finish; they just smell a little so mask and/or ventilated space is warmly recommended.These arrived today from the shop, cheers John.
I just lost patience with my usual Vallejo acrylic’s on my last build so thought I would give these a go.
I may be forking out for a few more if they are any good.
Geoff.
Thanks for the info Andrea :thumb2:I used those paints and the result was nice: thinned with its own thinner, easy to spray, give a smooth and a semi matt finish; they just smell a little so mask and/or ventilated space is warmly recommended.
How lucky you are to have a local, good bookshop....... and some more reading material from the well-stocked bookstore:
A bookstore that was voted the best in the country at one point, even. That doesn’t mean they’ve got a good (or even any real) assortment of books about military vehicles, but it pays to browse the historical section from time to timeHow lucky you are to have a local, good bookshop.
Love those Vickers guns in particular!As I’m used to building aircraft with lots going off in the cockpit the Sopwith Camel is definitely a little sparse on the inside so I’ve got a few bits to bling it up a bit. I’ve got a new instrument panel, new seat with cushions and some new machine guns.
Might be worth asking Neil if he could re-scale them for you? I'm in two minds whether to add some sort of military scheme or leave them as civilian vehicles.Hi Dave, those do look rather nice all painted up......I've been visualizing them in 1-87 scale with OD green paint and stars on them.....Hmmmmm.:thinking:
No mate, I've got some modern PMC guys I can use, I'll try and scratch some bits together for either an Italeri Landie or Takom Mitsubishi or maybe even both?!Are you going to use the zombies to fight the US troops?
