Eduard 1/48 Bf 110E
Welcome aboard Andrew.
I think the largest "stash" I've ever had was 4 kits lol, I tend to buy & build on a whim.
I've got more part-finished diorama than that :tears-of-joy:
You obviously have a lot more self control than myself. My bedroom used to be massive now I just enough room for my bed Lol
A lot of this will be bread & butter to many of you guys but for someone at my level it's been very fiddly so far, so I'm going to make a big deal out of it :smiling5:
Cockpit went together well but the individual control levers were a wrestle. I also lost one part after it went supersonic from my tweezers, so scratched something similar. Some form of canister with a hose coming out of it.
Then I folded up a couple of small boxes for the IP and side wall, to have painted etch pieces added later.
Not great but the best I could manage.
The ammo drums needed some etch adding too. Some are a bit wonky but I amazed myself by actually managing to fit them all!
The kit does provide plastic parts & decals as an alternative to most of them, so that's a fallback plan.
I was admiring the well weathered tank tracks lol
That’s a shame. It’s really unusual for Eduard to have that kind of problem. I’m sure they would be willing to post you out some trees for compensation
Ok Andy, I'm still trying to ketchup with the other 15 builds you've been doing and here you go starting another one...And a really cool wing thingy one too!!! I'm having trouble doing etch in 1/35, for my Kübelwagen and you're knocking it out like nothing, in 1/48!!! Respect Sir!!! That IP also came out really, really nice.....
Allen
Thanks Allen. Most of the etch isn't as well executed as I'd like but I hope to get better with practice, and there's plenty more to go at in the box.
Hells Bells mate I couldn't even see it that well with my one good eye. Starting to look great .
Ha, I was struggling with two John, and it was pinging all over the desk at the slightest touch :smiling5:
Wrestled some of the etch dials into the sides of the fuselage:
And some more above the gunners area. The decals for the radio gear etc looked cartoon-ish so I removed them and did a bit of painting / dry brushing instead:
IP and twiddly stick were added in the office and the seat belts were constructed & fitted:
I'll throw some muck & dust around then this can be closed up and hope it still fits in the fuselage.
That's looking excellent Andy,nice one :thumb2:
Cheers Andy.
Seat belts were fun :tears-of-joy:
I'd much prefer some nice, easy Quinta ones next time rather than trying to bend & glue up to 4 pieces for each strap lol
Probably the best view you'll get of the cockpit tub in place. It all fits together very nicely indeed:
For those that may build this kit in the future there seems to be a mounting point for another magazine under the radio gear, very visible here. However there's no mention in the instructions nor is there a spare one on the sprue, so the more conscientious of you may want to fill it before painting. Part C18.
I might hide it with the pilots lunchbox and flask of tea or something lol
And here it is all closed up:
It'll definitely need some filler around the back of the cockpit, near the rear MG mount, but with any luck some sanding & rescribing might suffice for the main seams. I chamfered the mating surfaces ever so slightly to ensure the outer, visible part met first, squishing out a bit of molten plastic as the halves were pressed together. Seems to have helped but we'll see once it's dry. I've brought it into the house as it was 9°C in the shed and set to drop overnight.
Thanks Tim, much appreciated.
I've just realised Eduard do this bird in 1/72 with similar etch details.
How. On. Earth! :surprised: :smiling5:
By eck! My first time with an Eduard kit and it's not exactly turning me into a fan! :tears-of-joy:
I'm hoping it's just a Friday afternoon kit though so won't judge the brand on this one build. In fact I've ordered the 1/72 version as I'm feeling a bit masochistic lol
This was the result of gluing the halves together. Nice squeeze out along the main seam that ultimately sanded down sweetly, but that huge step at the rear of the cockpit has taken many rounds of filler. I'm not sure why they bothered adding surface detail around here as it's all had to be sanded away:
On the plus side it's giving me plenty of practice at scribing panel lines. I've never been very good at it but I'll have a few miles under my belt after this kit:
Rivet lines still to do.
The front gun bay was a disaster of poorly moulded parts but thankfully it'll never be seen. Because of that I've snipped off the MG's so I don't have to deal with them poking out and getting snapped off while painting.
I've added & drilled some thick card so that I can (hopefully) thread them back in after paint:
And this is the best fit I could get on the nose section, even after an hour or so of trimming the flash & poor moulding from the inside. It wouldn't even have connected to the fuselage straight off the sprue.
There's some sprue goo filling the worst of the gaps and I'll see what it looks like in the morning:
So definitely not the kind of modelling that I'm used to, but at least it's keeping me occupied for longer than normal :smiling3:
Wow Andy, it looks like this one is putting up a bit of a fight...As for the fit probs, it might be that the molds for their 110 series of planes are kind of old and maybe worn a little. They have made quite a few different versions and re-packs of it...
I am glad it is keeping you occupied longer too Sir! Gives me a chance to keep up with your great work and not always falling behind on your builds...
Allen
That is definitely a Crap fit Andy! I have all the confidence in the world that you'll get it sorted! :thumb2:
Surprising that an Eduard kit needs so much work, but if anyone can sort it it's you Andy.
Thanks for having confidence in me chaps. There's a ton of detail that's been lost on the underside too. Time to test out my scribing game. Or a ditched diorama maybe? :tears-of-joy:
One reason for ordering the 1/72 is that it's a newer mould so will hopefully be a better experience. Although to be fair I've done 70's Tamiya kits that fitted together better than this lol.
..... Blimey!!
This isn't exactly getting me keen to build my one.... what a nightmare!!:astonished:
