The deflector dish will be lit the problem with the pylons probly stem from having to take them apart a few times to correct the lightingHI Peter well my nacles on my enterprise met up lovely an i had no probs on the jionts rumon that you have an are you goin to light up the big blue deflector ? as ive done mine an it looks fab an really set the ship off but you are gettin there keep up the good work my freind
ATB
Chrisb
OH i see about thats your probloms on your nacles then as on my pylons i had fitted in the pylon a 24 pin male plug to feed eletric to the big 5mm LEDS with a 24 pin female plug to just clip into an no gaps but keep on workin on it you are doin well as this is a complex kit :thumb2::thumb2::thumb2:The deflector dish will be lit the problem with the pylons probly stem from having to take them apart a few times to correct the lighting
I have lost my mojo for all things lightly uppy as the wiring was beginning to boggle the brain so I am taking a little break and I am building something a bit more straightforward but hang in there I will be back.HI MR AirFix is there anything more done on her ?
chrisb
OK Peter hang in there then an be like arrnie sayin I'LL BE BACK LOLI have lost my mojo for all things lightly uppy as the wiring was beginning to boggle the brain so I am taking a little break and I am building something a bit more straightforward but hang in there I will be back.
HI Peter would you mind givin me this gents email address if poss as it would be nice to try my hand at makin up these circit boards kits to fit in my next kitThanks Chris luckily if I do mess up the guy that does these kits is so helpful I can easily get replacements.
What I will do I will give an eBay link to one of his lighting kits and you can contact him via ebayHI Peter would you mind givin me this gents email address if poss as it would be nice to try my hand at makin up these circit boards kits to fit in my next kit
cheers if you can sir
Chrisb
OH CHEERS Peter many thanks sirWhat I will do I will give an eBay link to one of his lighting kits and you can contact him via ebay
https://www.ebay.co.uk/itm/283475538985
Or there is a Web site
https://startreklighting.co.uk/prod...701-discovery-11000-scale-model-not-included/
AN HI John what are you a trekkie like peter an me ? AN GOOD ON YOU IF YOU ARE SIR as i find this type of modeling very excitingPeter, somewhat annoying to say the least ,bet you said more than that.
Would be nice to see this on the go again.
I will build to the point where the saucer section is ready to be joined to the restOH Peter so i gather you are goin too plunge on with this kit an not that tomcat kit then an you are doin a grand job sir keep it comin
chrisb
