Special Hobby 1/48 Pfalz D.XII Early Version Inbox Review
Dave Ward
Special Hobby are a Czech manufacturer, they've always been a rather short-run modelmaker, but as years have gone by, the quality has improved, and now are mainstream.
The Pfalz D.XII was designed in 1918, it was a good fighter, but overshadowed by the Fokker D.VII, around 750-800 wwre produced by the Armistice.
Soft end opening box, the same illustration front & back. 2 grey plastic sprues, small sheet of PE, bag of cast resin parts, decals, instructions. This kit dates to 2004 - I supposr the cast resin parts would now be 3D printed, just a little more clean up needed
Sprues are pretty clean, detail is a bit soft in places, no part numbers, no locating pins - very short run
These planes had plywood covered fuselages, so the detail is sufficient the wings look OK, but thay will be covered!
The rib tapes ( lower left ) are the really tedious decals to apply.......................
Resin parts - radiator, seat & cockpit fittings the PE has seat belts & some other minute parts!
The instructions are B&W A4 folded paper - a little small, but you can download the instructions from Scalemates & look at them blown up
DSCF4755.JPG They are pretty clear - colour call outs are present
At least there is a rigging diagram. no matter how small!
DSCF4752.JPG There are 3 finish options, differing only slightly ( anyone know what 'griseous' is? )
An odd thing I noticed on the box was the safety disclaimer - normally it says something like 'not suitable for under 12' - this says 15! I must have missed the dangerous part!
WWI biplanes are never going to be everybodies cup of tea, they can be very difficult, especially when you rig them - compound this with the wings being covered with lozenge decals, and you have a model that is not for the faint hearted! I've done a few including the Fokker D.VII
More lozenge decals, but not a lot of rigging.
My method would be to complete the decals on the upper face of the lower wing & lower face of the upper wing - assemble the fuselage to the wings. Then, with a fine drill ( 0.3mm dia ) make the rigging holes. Using 0.25mm dia monofilament & CA rig!. Make good the upper/lower surfaces & hide the mess with the lozenge decals! - At least that's my initial thought!
The model is out of production, so Ebay & pre-owned websites are the only places to find this - I lucked out & picked this up for £12 includind delivery from Ebay, a very good price!
The only other 1/48 model of the D.XII is the Blue Max version, a really short run model from 1994.
Thanks for dropping by................ any comments and thoughts on how you would assemble this will be welcomed
ps - at last my right hand is becoming useful - I might get some benchtime in at the weekend!
"anyone know what 'griseous' is?"
Mottled or streaked with grey, according to my dictionary. Now I need to build a 109 so I can say the lower fuselage sides are griseous!
Looks like there's a swastika in the decals , any idea why when it's WWI?
I know it was around long before the Nazis hijacked it forever, but I'm curious, is one of the options an early Luftwaffe one?
I
I can’t see a swastika Neil!! Where exactly is it?
Doug, it's right below the pilot in the cockpit on the box cover. It was considered a symbol of luck and was painted on many WWI German and other nation's planes. It is hundreds of years old...
WWI aircraft had a lot of strange markings/symbols painted on them as well as their camo schemes. Here is one of my favorites,
This was painted in both German and English on WWI German planes. This one is a Rumpler C.IV late model......
Allen
Pete,
Buy a tin of alphabet soup, be surprised how many new words you can get from it....
Allen
They also had a captured Bristol Fighter, but the inscriptions were in German.
Finland also used the swastica before they came up with the blue and white roundel.
Not uncommon to find on WW1 aircraft. Apparently it became fashionable pre war after archeological digs in the Troy area found some. Here’s an illustration of one on a camel in the good luck position (Middle picture).
