Brian's 1/48 Dkm u-Boat Type Viic U-552
All this talk of copious amounts of water makes me soo envious, as ex-Infantry our water frequently tasted of either 'steritabs' or that horrible plasticky taste you get from jerry cans when some plank has left them out in the sun all day.
Could have been worse though, you could be lucky enough to get 'range stew' for lunch...this stuff often festered in the 'Norgi' all day, (although it tasted like it had been in there about a week), before the cooks would think its a good idea to feed it to us... thank god for ration packs..and good old cheese possessed...
look's like an F1 pit stop, but with a helicopter
Where do you think F1 got the idea from!!! ~everyone had a job and it was well practiced. My job was usually to sit there, hands on head!! (away from the armament switches!!!) :smiling2:
You should have seen us do a weapon load!!!! 3 minutes, refuel, two Mk44 torpedoes and away!!!! A couple of minutes and we could have two air to surface missiles stuck on!!!! AND we never ran over a mechanic!!!!!
I forgot to mention the swimming pool, en suite showers, and the steward served 5 course meals! Against this was a minimum of 5 months away from home, with only few hours time off - I've been to Tahiti ( Papeete ) 5 times, but never managed a run ashore - maintenance on the main engine, after 30 days+ at continuous full power ( 12,000nm ), was priority. Not strictly continuous - we had the Panama Canal transit in the middle!
Bummer, I bet you didn't have an 18 inch wide bunk bed in a stack of three with anything from 6 to 50 blokes in perfect harmony!!!!!
Mind you, I bet nobody was firing missiles at you then either.
I need a decent soldering iron struggled with the cheep one I have but you get the idea :)
briliant, in my opinion it's just the right amount of 'gloominess' to emphasize the claustrophobic conditions inside perfectly..
I have never painted figures and going to need some pointers off the guys that do it regularly :) there is 22 of them :dizzy:
Had half an hour start on the control room.
Had a bit of a go this morning.
got some seams to sort
IMG20240121111541.jpgIMG20240121111551.jpgIMG20240121120712.jpgIMG20240121120720.jpgIMG20240121120928.jpg
Done for the day.
Hi guys deckhead is finished and started the aft bulkhead its very time consuming waiting for everything to dry (still knock stuff off)
A coat of gloss varnish ready for the weathering
It all looks too new! when it's dry I'll do some weathering.
Did a bit of weathering going to let everything dry and build the control room up tomorrow
Hi just finished getting all the parts ready for the control room assembly got to admit it's a pain having to paint all the parts (clean and put the AB away then find something that needs painting)
IMG20240125085400.jpgIMG20240125085409.jpgIMG20240125085413.jpgIMG20240125091807.jpgIMG20240125091814.jpgIMG20240125103219.jpgIMG20240125103223.jpgIMG20240125103226.jpgIMG20240125103232.jpgIMG20240125103236.jpgIMG20240125103239.jpg
