Thanks mate.OK, in that case I’ll just link to a short version :smiling3:
http://www.missing-lynx.com/gallery/usa/pattonsmsa1scoutcarsz_1.html
Cheers Jim, I have tried out some Quinta rivets on the other panel. And I am quite impressed they take a bit of getting used to but I think they look a lot better I will post a comparison picture tomorrow. Trouble is it does mean I have to redo the other side.A lot of very neat work Scottie. Really looks good. As to whether the the size of the rivets look ok it is difficult to judge until the whole side is tied together with a coat of primer.
really? is anyone going to see both sides at the same time....?Trouble is it does mean I have to redo the other side.
Neil, very true but I would know plus it doesn't take that long.really? is anyone going to see both sides at the same time....?
Cheers Tim, I must admit I am happy with the lock.That door lock is spectacular Scottie. The new rivets are much better as well.
And so you should be!I must admit I am happy with the lock.
Cheers Pete.And so you should be!
Thanks Jakko.Agreed, the new rivets look better probably because they’re not as tall. As for the lock … if you were to tell people this is a 1:12 model they’ll believe it too.
Thanks Joe, I am having lots of fun doing this.Paul such AMAZING detailing going on but I’m still having a bit of trouble focusing while still laughing at your punched nuts comment … that lock is FANTASTIC
Cheers Brian, good to see you.Paul just found this thread and I'm blown away with the detail you added to this model (that rear axle wow)
Paul, please stop, Sir ! I can't take any more !The side panels have now both been redone. I think the rivet detail looks a lot better. Some detail has also been added to the inside of the panels as well. I still have the tie downs to add but will do them later so I don't knock them off.
The inside detail of the drivers door has been done and when dry I can do the outside. The map pocket is PE the rest is scratched.
work has started on the rear panel.
cheers
Scottie
Ron, I think you could be right.Paul, please stop, Sir ! I can't take any more !
Thanks Markgreat stuff :thumb2:
