Rick’s 1/72 Airfix Chinook HC1 - Bravo November - a dream sheet build
rickoshea52
Rick
Next on the bench will be Airfix’s brand new tool Chinook HC1 in the BN markings.The only Chinook that made it to the Falkland Islands in one piece, of the others embarked for the journey south one was off loaded at Ascension while the other three were lost on Atlantic Conveyor.
Bravo November, serial number ZA718 has the distinction of being the mount flown by no less than four Dintinguished Flying Cross winners.
The detail on the newer hard plastic is very crisp and fine, some of the smaller parts look quite delicate and will need careful handling. This boxing can only be built as an HC1 from what I can see. The fuselage halves are on separate sprues suggesting a different sprue for later marks. One of the obvious differences between an HC1 and HC2 is the front face of the aft rotor pylon. The HC2 gained a large opening resulting in two new liney slang terms - the bog seat and the Bentley bonnet.
The detail parts include very nice pipework around the ramp but this was not a feature on HC1’s as this was covered over, later marks have this exposed. The troop seats are as good as you’ll get with injection moulding. Cargo hooks and load beam are well detailed as are the cabin floor and (rudder pedal-less) cockpit. But no cabin interior quilted sound proofing.
The glazing is super clear with moulded on RHWR fairing on the nose. One other clue of a later marks is the inclusion of IR jammer equipment similar to those fitted to RN Sea King HC4’s for example. However, this is moulded in regular plastic while the same part in Airfix’s HC4 is on the clear sprue.
Chinooks could be armed with M60 machine guns mounted on the ramp or, as was common in Northern Ireland, at the forward entry door. Mini guns were also sometimes carried hut Airfix has not included these as a build option.
I’ll make a start this weekend or during the following week when I’m away on business needing something to occupy me other than the hotel bar and football.
Box art and sprue shots.
IMG_3411.jpegIMG_3413.jpegIMG_3414.jpegIMG_3415.jpegIMG_3416.jpegIMG_3417.jpegIMG_3418.jpegIMG_3419.jpegIMG_3420.jpegIMG_3421.jpegIMG_3422.jpegIMG_3423.jpegIMG_3424.jpegIMG_3425.jpegIMG_3426.jpegIMG_3427.jpeg
The cargo hooks above and load beam below.
Delicate cyclic control columns.
Forward entry door has open or closed option with neat detail.
The RHWR fairing moulded into the nose glazing piece.
The decal sheet - very well printed
Above is the IR jammer from Airfix’s Sea King HC4 (common to the HAR3 boxing too I think but not used) this is on the clear sprue.
Below is the Chinook version - parts 13 & 14.
Cool. I have this on my list for the future so will be great to see what the kit is like.
Very nice detail for a 1/72, I'll follow along if I may, this should be interesting.
I never understood that. The UK’s standard machine gun was/is the MAG, or GPMG as you guys like to call it, yet for one type of aircraft, the RAF went for a completely different gun. Even if they came for free with the helicopters, it makes little sense to me, logistics-wise.
This should be a really interesting build!
That's interesting, I didn't know that. I don't think I've ever seen a photo of an RAF Chinook armed with a M60. tbh, I don't think I've seen a picture of an early RAF Chinook armed with anything. I know latterly they had miniguns and the like.
Not forgetting a SK with a Gimpy!! (An ASW Sea King at that!!).819NAS-Otterburn-GPMG-1.jpgAnd that is me!!!
(Even the Wasp could be fitted with a Gimpy!!)
Lynx had the M60 I believe. (As well as a Royal Marine sniper when needed!!)
Same ammunition as the jimpy.
Step 2 and I’ve found a problem. Fit part G25 but then there is no sign of it in later steps illustrations. Then step 12 tells you fit a completely different instrument panel! I ignored step 2
62CB9C40-A7F2-4B2E-86FD-F13EDC6B60DC.jpegB9018965-BAE1-416D-8B74-B72C64E84BAC.jpegA30FD012-7DCC-441C-A78E-514469756C56.jpeg
How I painted the troop seat. Spray them red, front and back because they are visible through the cabin windows, then mask so only the framing is exposed and spray them grey or aluminium. I also brush painted the lower frames with thin grey lines to replicate the cut outs of the fabric on the real thing.
It’s a shame the cut outs on the fabric seat backs aren’t moulded, this will have to be done with a was ‘cos I ain’t cutting them out. An aftermarket company will be along with etched sets soon, in fact the Eduard set for the Zvezda C-130 has similar seats.
45F7AAAE-5B9F-4FEE-8F14-3E60A854376F.jpegCCFFCAF6-0E3D-427A-A0B2-709C516F7EF1.jpegD20C7941-0F22-48F0-9CCB-DCAD7FEECD0B.jpegC96CD62A-1DDB-439E-8FDA-93987EBEF774.jpeg
On the real HC1’s the airframe around the ramp does not have all of the frames and pipework exposed, this was from HC2 onward. The easy solution is to do the cab with the ramp fully closed but I want to have this open. My solution is to cut some thin plasticard to shape, engrave some detail and a cut out for the hydraulic hand pump then glue it over the exposed pipework.
Using a red paint pen to aid marking out the cut outs around the ramp and black pen to aid the positioning of the engraving template, surface detail and that cut out was done. I used an engraving tool bought in Japan and the templates from John’s shop.
025F21C4-7168-435B-8F47-73D4FBCD4C3A.jpeg64CBEE4F-090E-44C1-84AC-B7D976379746.jpeg076DE44F-AC48-44E4-A211-9F447DC47D23.jpeg58F6646A-A172-4D6F-B072-94B21D0B35D8.jpeg5D3C01CB-A9F7-4E00-9E70-E555172B8F5E.jpeg6C1380D3-54FC-488E-AFAE-DF2498C072A5.jpeg84386D99-5128-47AB-AFA1-2492969B9256.jpeg5CF08389-37E8-4C1F-844F-B70C5F2E90FE.jpeg7C291238-85E1-40A9-AAC4-C6787FF43C37.jpeg
Floor and ramp painted.
Lots of drilling done using the Gucci little jigs included for the holes on curved profiles. These holes are for the door winch and numerous aerials on the underside, pay attention to the different hole sizes.
1C9B7EA7-B7B7-4EFD-9B09-21393C8C69A1.jpeg11A9E906-E28C-42D6-B1BB-2B3C0EB192BD.jpeg69F73B6F-6C24-4F9F-97EE-CF1C06EAE035.jpegF72AB9E6-26F9-4275-9D40-6E3DC980C3D2.jpeg11ED98D4-2BDF-4219-84F5-706676371A6D.jpeg612364ED-0A01-41C1-AE4E-B66056838B01.jpeg
Nice start rick ,lately ive been tempted to bust out the 1/48 Revell Chinook ive got in the stash - might need to clear a big space on the bench though!
Following this build with interest Rick. I have seen a few good reviews of this kit. You certainly seem to know your stuff so I'm sure you'll build a great model.
Troop seat progress tonight with the installation of harnesses, a lot of harnesses.
2mm tape tacked onto a sheet of plasticard then painted Tamiya olive drab. Once dried it’s cut into sections at 7mm & 4mm lengths, one for the short strap and the other for the longer adjustable strap. As you can see, I ran out of painted tape so I’ve done another strip for the cockpit seats and to simulate aircrew dispatchers harnesses.
A feature of any RAF helicopter is the variety of “role equipment” carried; stuff like strops, blanks, kimwipe and in the case of the Chinook a step ladder and sweeping brush. Usually stowed against the left hand aft face of the cockpit bulkhead these mundane bits of kit are essential to Chinook maintenance.
I tried my LMS for plastruct ladder stock but they had none so some basic scratch building was required. My first attempt at a broom looked unconvincing so I had another go using 10thou plasticard laminated (for the bristles) in three strips, trimmed then glued to a 20thou strip as the wooden block. Thin brass wire for the handle instead of plastic rod.
Once dry they’ll be painted and the brass cut down but see what you think. Cocktail stick for scale.
