Thanks Neil.Loving this John, bring it on!
Don't know about that Joe:smiling2:, still need to pop some bubbles later so looking fwd to that. Had the weed burner out yesterday on the gravel drive, now that was fun !Goodie goodie another water dio…staying away from fire for a while? Must be the pyro police keeping you in check…
looking forward to another Fantastic dio from you
Thanks Dave, as for the help your most welcome :thumb2:Well done buddy a little perseverance and a step back every now and then to give yourself a pat on the back helps keep the right mind set , now you've primed up you can see it was worth the hassle ,look at it as the driving force to reach the part of the project that you enjoy the most you've had the smoke now bring on your fire.
Thanks for all your help recently as they say its good to talk. Dave
Many thanks Steve.Looking good John - the diorama is developinh very nicely!
Many thanks , that's one for up !That is looking pretty impressive already. I’d say barrel up looks more desperate and stranded than barrel down.
Thanks my friend, that's one for down.I’m going to vote for downward, but just slightly into the water as if there was not enough time to react
Hadn't even crossed my mind Dave, that's very helpful.Just a thought John without some sort of break on the traverse ring surly it would be looking down going by weight first
Thanks Jim, your not the only one either, going to to have mine as down now.:nerd:That's a very useful SBS of how the base is progressed.
I was going to say barrel up but having read David's post I reserve judgement :rolling:
Tank turrets are fairly well-balanced, else they become hard to traverse on an incline, so I wouldn’t think it’s implausible for this one to have its gun barrel up into the air. And there will be a turret lock that secures it in whatever position the turret is in when it’s applied, but I admit it would be odd for that to be engaged with the turret at about 10 o'clock rather than at 12 or 6.without some sort of break on the traverse ring surly it would be looking down going by weight first
