- Joined
- Apr 27, 2018
- Messages
- 14,905
Love it mate.
Waiting for a couple of bases to dry after adding the ground texture, had a look through the stash and came out with this.
But I had forgotten that I had done some earlier work to change it into a Mk.12....
I had started off with just the mantlet, then added the front top of the turret and realised that the turret now had to be re-shaped... So set to work with filer and two part putty before getting the basic shape with a knife and finally sanding to shape. Then a final coat of filler (Tamiya) and a sand down got me where I wanted to be.
These are the products obtained for the conversion. The turret roof (SMM) was obtained just in case I totaly messed up the turret, so is now spare. The 'Pagoda' engine louvres are a resin part from Scorpion Miniature Models, Firestorm have provided the wheel 'rubber' tyres as I am too lazy at the moment to get out the casting resin and produce my own... And the tracks are the AFV Club workable Centurion tracks (180 per side)....
Would not be a build without the etch, so it will be new bins, plus odds and sods, the Bazooka plates will possibly not be used as there are a lot of tie downs to add, but we shall see...
Here is the reference material in paper format, plus of course the interweb will provide other information. (notice the tie downs....)
First job today was to cut off the rear, ready for the new rear end of the engine bay....
And here it is test fitted, again from SMM, it will not be glued in place untill I am ready to start fitting the engine louvres....
The glacis plate has a new strengthened plate added over it, and I did not forget to remove the awfull injection pins from the underside....
Try taking them off when fitting the tracks....
The deck plate has a 3mm piece removed from the rear and the fuel filler caps removed and sanded away, also the 7 bolt holes are filled as they are not required...
And that is where I am at end of play for today, as you can see there is a metal barrel in place - I do have a resin one, but at the moment I am not too happy with it as there are a couple of air holes with one at the muzzle end of the barrel, so I could end up making my own....
More later
Mike
I think i remember a German 3d producer who makes the range finder set up so could be a definate to do.Fancy doing a welded Cromwell tank first in 48th or 35th.Not great many pics of them sadly.Do it, you don’t see those built very often (except, I suspect, a model shows in Denmark).
I had the resin barrel as part of the upgrade to a Mk12, but no matter how I set it the damn thing took on a life of its own and would not set straight. And having done the metal barrel before on my other Mk12, I thought it would save time....Is there a particular reason why you would change the metal barrel Mike? I thought they were the bee's knees of gun barrels.
Go for it...Fantastic Mike.Been mulling over doing a Danish cent with the laser range finder and Pzb200 pointer thingy.
Rich
Many thanks Dave,Sorry Mike this one slipped under the radar but all caught up now ,very powerful stuff indeed ,as I always say about scottie(Paul) 's)work inspirational ,I fear for your mental welfare as I do his but I've a feeling its what you thrive on ,inspirational not to emulate what you do but seeing stuff like this just makes me happy to jump up to the table and bash on with what I'm up to happy with my lot pushing my own boundaries. Cheers Dave
They look 100% better than the resin parts. Good decision. :thumb2:Bit more...
The resin springs were replaced with ones from copper wire...
Loved Bill Herne, Roy Dillys little figure vignettes in the airfix magazine, who was the chap that built the Historex figures Max Winters? The late Sid Hortens figure builds/conversions of the few returning from the charge of the light brigade based on the famous painting ran for ages in the airfix magazine ,Ray Lambs excellent figures for Hinchliffe? Phoenix did some brilliant stuff as well including some cricketers ,yes many years ago you can tell I got into this first figure painting even used to travel up to Southampton once a month to the Southampton branch of the BMSS before moving on to plastic all such a long time ago now. DaveMany thanks Dave,
Scottie and myself were joined at the head at one time, where we shamed our family by detailing dinosaurs, changing big arms for little arms etc. And after separation down in Grandpa's rickety old shed at the bottom of the garden, we were taken out and placed under distant Goosberry bushes for some unsuspecting family to find... and find us they did, and of course we were not happy in our respective caves and set to detailing them - and that is how you now have high rise flats....
I (we) are pleased we inspire and encourage you and others onto their bench to make a model, this is what the hobby is about. Modelmakers I looked up to were old names like Bill Hearne, Roy Dilly, Harry Woodman and John Sandars to name a few, all inspirational and all got me onto the bench to try to make wings for WW1 aircraft, figures and conversions, afv's out of card which all led onto scratchbuilding and detailing.
So go ahead and make what makes you happy and keep pushing your boundaries...
Cor! Dave we are showing our age....Loved Bill Herne, Roy Dillys little figure vignettes in the airfix magazine, who was the chap that built the Historex figures Max Winters? The late Sid Hortens figure builds/conversions of the few returning from the charge of the light brigade based on the famous painting ran for ages in the airfix magazine ,Ray Lambs excellent figures for Hinchliffe? Phoenix did some brilliant stuff as well including some cricketers ,yes many years ago you can tell I got into this first figure painting even used to travel up to Southampton once a month to the Southampton branch of the BMSS before moving on to plastic all such a long time ago now. Dave
