They do have one small problem that nearly all of these kit drive sprockets suffer from, though: the flats are in the wrong place relative to the rollersThe sprockets are also multiple part with some great engineering and detail.
I’d think this would be an emergency thing only. The Sd.Kfz. 10 was a 1-tonne halftrack, meaning a pulling power of one tonne (cross-country). The 10,5 cm le.F.H. 18/40 weighed just under two tonnes, so it would have been doable but not easily. Still, if the enemy is approaching and all you’ve got is a one-tonne halftrack, you’ll use it to tow that two-tonne howitzer.The eagle eyed among you would of spotted the Sd-kfz 10 came with a 5cm Pak 38 but I had the 10.5cm leFh 18/40 in the stash and wanted to use that instead.
