Morning All,
As the Mojo is flying and I ain't getting any younger, I decided to dive into another WWI wing thingy. It will be the conversion of the Albatros D.I fighter, into an Albatros W.4 (late) float plane used at Zeebrugge in the Great War. It will be a test of nerves and skills with chopping, hacking and scratchy work to do it. First up is a little background history of the plane...
The Albatros Company was a major producer of fighter aircraft in the Great War. Their D series, I - V, were some of the best single seater fighters made and flown by many Aces at the time. Albatros also produced a series of float planes for the Naval air services too. The W.4 was built from the original D.I airframe, with the addition of floats to be water capable. Both planes used the Daimler Benz D.III inline 6-cylinder motor rated @ 160HP. Testing found that the W.4, being heavier than the D.I, had difficulties getting into the air. It needed larger wings to accomplish this. There were also other design changes made to the tail. A quick spec comparison of both models,
..................................Abatros D.I............Albatros W.4
Wingspan upper - 8.50 mtrs.............9.50 mtrs
Wingspan lower - 8.00 mtrs.............9.20 mtrs
Fuselage length - 7.40 mtrs.............7.40 mtrs, 8.40 mtrs w/Floats
Top Speed - 175 Kph..........................160 KPH
Empty Weight - 898 kgs....................964+ Kgs
There were 3 prototypes, #s 747, 785-786 built and tested. Followed by 7 production runs made between 1916 and 1917. A total of 118 of the W.4's were made. The production runs were as follows including marine numbers,
1st, #s 902-911 with 1 08/15 Spandau LMG, with 2 ear radiators, 10 built...
2nd, #s 948-967 with 2 08/15 Spandau LMGs, with 2 ear radiators, 20 built...
3rd, #s 1107-1116 with 2 08/15 Spandau LMGs, with 2 ear radiators, 10 built...
4th, #s 1302-1326 with 2 08/15 Spandau LMGs, with 2 ear radiators, 25 built...
5th, #s 1484-1503 with 2 08/15 Spandau LMGs, with airfoil radiator, 4 ailerons, 20 built...
6th, #s 1504-1513 with 2 08/15 Spandau LMGs, with airfoil radiator, 4 ailerons, 10 built...
7th, #s 1719-1738 with 2 08/15 Spandau LMGs, with airfoil radiator, 4 ailerons, 20 built and shipped directly into storage...Outdated and superseded by other float planes. Hansa-Brandenburg W.12, Friedrichshafen FF33L, Rumpler 6B1 etc.
So you are now all asking what this has to do with the price of pigs in Poland. I wanted to get this done before I forgot, like last time!!! What I will be attempting, as said above, is to convert a D.I into a W.4 (late) from the 5th or 6th production run...........The victim,
The kit is from 2008 and not anywhere near expensive as a WnW kitset...The sprue shots,
Some flash, two different colored plastics which are rather soft, pretty good details (wing ribbing is weak), and the motor needs lotsa love!!! The destructions,
The two big hurdles in this conversion are, scratch building the floats and lengthening the upper and lower wings. The other hurdles are easier to accomplish. This will be not take away from finishing my dio...
Feel free to pull up a chair on the dock and watch me drown with this one.Butchery Construction will begin very soon. You have been warned!!!...
Allen
Allen
