1/32 Revell 1956 Cadillac Eldorado
Jim R
Shropshire
I was looking for something in the stash, box in spare bedroom, and came across this.
I have had it for many years. I seem to remember it was part of a "job lot". Not only is the car of 1956 vintage but so is the kit. Made when Revell was an American company.
Very simple instructions and rather a lot of flash.
Normally I would have swiftly returned it to it's place at the bottom of the pile. However it looked at me and said "I dare you!" I wanted something which wouldn't matter if it ended up in the bin, something cheap and unimportant. Also there has been a recent thread on the forum about polishing to get a good gloss, something I've never tried, so I thought this might be a chance to have a go. Consequently this geriatric ended up on the bench.
First job was the front axle/suspension. The kit part was hopeless. Now I have no clue about cars - I wouldn't know a spark plug from a fan belt. My idea of a maintenance check is to count the wheels - 4 and I'm good to go. ( I do however have a most excellent local garage so my car is well looked after ). I modified the suspension, probably not accurate but looks better.
The back suspension was also pretty poor. I made new springs. The kit part is at the top.
That's the underside done.
The rear springs look odd but I've checked and they do fit at that angle.
I'm actually having fun - no pressure :D
Thats right up my street jim ! An ancient kit of a brilliant subject . Looking forward to this , are you going to use the figures too?
The box art is fantastic too , worth framing and hanging up in the model room .
Some progress in between garden jobs - SWMBO speaking "At last the rain has stopped so we need to tidy the garden". Translates as "Stop messing about with those bits of plastic and get out there!" :D
The kit does not supply a clear part for the windscreen. I cleaned up the frame, had to cut off the wiper blades, and made a template from masking tape.
I used that to cut out a slightly larger piece of thin clear styrene. I held it in position on the frame with little clips and wicked thin CA into the join.
After 24hrs I trimmed the edges and gave the screen a bit of a polish. Not perfect but should be OK. Bit of a gap, bottom left, but I'll live with that.
All the chromed parts were stripped with bleach. I don't like kit chrome - always seems too thick and shiny. Also correcting fit issues destroys the finish and can't be patched.
The canvas hood and the cab carpet were given a bit of texture with Mr Surfacer 500.
To answer Tony's question - Yes I will use the figures. They took a lot of clean up but are actually rather nice and fit well.
Thanks all for looking in.
Doris day and clark gable are looking rather good jim , great work on the windscreen , cheers tony
I have managed to get the body together. Fit was OK although most of the locating pins had to be removed as they were either too large for their corresponding holes or in the wrong place. Worst was the bonnet - needed lots of weights and left overnight.
All parts mounted up for painting. The stripped chrome parts have a gloss black primer.
The chassis primed with MRP black.
The body will be red so I used MRP red oxide primer. Black for the door cards.
Thanks for looking in.
Looking good Jim, that body certainly needed some persuasion by the looks of it.
A bit of progress.
The paint call out from Revell was for the seats to be black and white. I thought this was rather harsh so used ivory and a grey. The seats are pretty rough, especially the rear.
I also painted the door cards. The two added little white styrene pieces are to support the dashboard.
The dash itself
Wheels painted.
It all looks a bit rough in the photos but looks better in reality - honest!!
Looking great jim , time to get the bling on !
Looking good. The 56 Cadillac Eldo. 365cu. in., two four barrel 305hp engine was a common swap in the late 50s and 60s with 55 Studebaker Presidents, to create 'Studilacs'.
I am ate to the party on this one Jim. What an interesting build thats coming along nicely.
Well 'tis done. Certainly not a kit I would recommend. It shows it's age of 70 years. Fit is terrible, moulding is rough and the kit design leaves a lot to be desired. So excuses over here be piccies.
Doris and Clark
And at the drive-in in Clark's new 1956 Cadillac Eldorado :)
Thanks for all your comments.
No excuses needed Jim - fantastic job . I love it , if I saw anything like this I would snap it up . I hope you saved the box lid , classic 50s style artwork worthy of framing for the modelling room wall!
