In my case Gerry the blowtorch would be better, as I could set fire to the bench :nerd:Soldering iron or blowtorch for the soldering? Sometimes it gives a better result with a blowtorch, but that is harder to do.
Did someone say fire!!!! :thumb2::thumb2::thumb2::thumb2::smiling3:In my case Gerry the blowtorch would be better, as I could set fire to the bench :nerd:
Thanks Paul, no forgot all about cleaning the PE ! Just knocked off one of the air intake screens to make matters worse.John,
A great build so far mate. Don't get discouraged with the PE it can add a lot but times it is no better than the kit part. As to soldering, you probably do this already but I always give it a good clean with scotch brite other names are available. then use a good flux.
Thanks Rick , that will do for me.If you think that is over sag JR, you haven't seen the late war or Berlin shots of Russian tanks that were about to walk out of their track assemblies!.....I still marvel at the fact that they held together. :thumb2: Rick H.
That's good to know Andy, thanks.Glad to hear you had a good time with the ak paint John, they certainly changed my mind about acrylics.
They still aren't quite up there with lacquers for super thin translucent layers, but for those that don't want to use lacquer, they are a great alternative.
I've had one dodgy bottle that clogged and splattered, but the rest have been fine, and I'm more than happy to use them where I'm not going for fancy effects.
Hi Dave yes please do ! Will wait with interest for your 1/72 Russian.Great stuff John so pleased you've given the alchemy the boot ,sorry you had bother with the link and length , I've found the secret to the pre sag ones is to stand back and make sure the top of each sag is on each return roller it should go fine from there,dont want to go into it here but if you want ill pm you with what I do with the separate link types in your kit ,as for the etch I think most of us struggle you've given it a bloody good go and got yourself and the rest of us further up the learning curve so well done , now your chomping at the airbrush looking forward to the next installment well done sir . Other half going back for Boris and taking all his stuff with her next week so after nearly eight weeks should get the work bench back got a nice little(1/72) bit of Russian lined up. Dave
Thanks Steve, yes I remember discussing that with MrT, The flip top is useless. We both decided that removing it when you needed paint and pouring was a better way.Nice work with the One Shot. Mr T and I had a conversation about making sure the paint is cleaned off the spout and lid and making sure it is fully locked shut when finished using. It seems it can easily stay open and dry out inside the the bottle. Great to see you falling back in love with your airbrush. Keep up the great work my friend
Morning Si, yes they look ok and the paint has stayed on them, didn't know how the rubber would react to the paint when I put them back on. Pleased with the sag, as long as the wire doesn't stand out too much. If you cut it any shorted the outer part of the track tends to curve over.Coming on nicely there John. Tracks looking good :thumb2:
Thanks Joe.:thumb2:Looking good John
Thanks Jim, if it works well I shall be really pleased, just need to find some more old style paper clips , they were just the right thickness and didn't bend. :smiling3:Hi John
The primer looks to have gone on nicely. I have a couple of bottles of Vallejo primer lurking at the back of a shelf. Only ever used them once or twice and they've been sat there for years. Like many I couldn't get on with them at all. I think the wires you've used for the sag will never show once painted in a track colour.
